Can the Hydro-Electric Engine Truly Achieve Over 100% Efficiency?
  • Context: Graduate
  • Thread starter Thread starter T3 + E =mc3
The Hydro-Electric Engine, as proposed by Jason A. Voigt, operates on a closed-loop system that utilizes steam on demand, achieving an efficiency of up to 180%. The engine employs a coolant system that heats water to create steam, which drives pistons or turbines to generate electricity. With a maximum operating temperature of 190 degrees Fahrenheit, the system claims to produce 90% more energy than it consumes, resulting in a self-sustaining mechanism that generates 40% extra power. This innovative design incorporates an electric cycle, mechanical cycle, and coolant cycle to optimize energy efficiency.
  • Understanding of closed-loop thermodynamic systems
  • Familiarity with steam generation and heat transfer principles
  • Knowledge of electric circuits and inverter technology
  • Basic mechanics of internal combustion engines
  • Research steam on demand technology and its applications in engine design
  • Explore advanced thermodynamic cycles for improved energy efficiency
  • Study the principles of heat exchangers and coolant systems in automotive engineering
  • Investigate the integration of renewable energy sources with hydroelectric systems
Engineers, automotive designers, renewable energy researchers, and anyone interested in innovative energy-efficient technologies.
T3 + E =mc3
THE HYDRO-ELECTRIC ENGINE
T3 + E = mc3
Time to the third Power + Energy = Mass - Circumference to third Power
By Jason A. Voigt
The three cycles in this system are closed loop systems after start up energy is applyed. once opeerating temp of 152 to 190 degree is acheived
then the three system just work in a loop so that the 1500 to 1 release of energy is done in the system form turning water into steam
Using this system free energy can be acheived read on to learn more about this.
The hydro electric engine
The basic of the hydroelectric engine work like this. It works with steam on demand and energy storage as heat with an electric cycle, mechanical cycle, coolant cycle.
Instead of having a boiler and storing water in a tank and heating all the water at once. This engine uses steam on demand technology. By taping into the coolant system of the engine and connecting this line to the fuel injection system. Then injecting the coolant on a heat plate between the cylinder head and the block. It makes enough steam to push the piston down and the then the piston push the steam out the exhaust. Where it goes back into the block and condenses back to coolant. Transferring the heat to rest of the coolant. The warmer the coolant in the block is it takes less energy to turn into steam. Therefore, when the coolant is at 190 degrees it only takes 22 degree more energy to reach the boiling point of 212 degrees. At this point, it would be running at 90% efficiency keeping 10% for safety. Then considering energy for start up of a battery and then having a closed loop electric system and on outside energy coming into the system it is really running 180%! 100% for engine operation and up to 80% free energy and 10% to keep the system running and 10% for a safety margin. This can be done with pistons or a turbine.
The Hydro Electric Steam turbine
Coolant system closed loop with energy storage as heat
Electric system closed loop
Turbine system with generator for electrical out put
The coolant system has a large tank with 500 gallons of coolant. With extra room for expansion with a radiator and thermostat to keep coolant from going above 190 degrees. The storage tank it also has a pressure relief valve.
Coolant is pumped to an injection system. Where it is injected into a tube with an electric heat plate that is at 500 degrees that turns the coolant into steam the steam that builds pressure in the chamber the chamber is coupled to a steam turbine witch turns a generator. The steam then passes through a one-way check valve so the steam can only exit the turbine. Then the steam goes back to the holding tank where it condenses back to a liquid coolant this also transfers heat raising the temperature of all the coolant in the tank. Therefore, when the coolant in the tank reaches 152 degrees this is the break-even point. It is now taking the same amount of energy to heat the coolant as you are getting
Out of the generator. So when the coolant in the system reaches 190 degrees. It only takes 22 degree to reach 212 degree to turn it back into steam at this point it is only using 10% of the energy that it would take to heat cold coolant. Therefore, the system makes 90% more energy than it does takes to produce the steam.
The system is now self-sufficient and produces 40% extra power free.
In this system, 100% is equal to 50% due to energy storage as heat with 10% free power
And 10% for safety.
So the total over view is 200% total power.
100% the complete loop of the system self sustaining
80% free energy
10% safety margin
By Jason A. Voigt
3/16/2004
Hydro Electric Engine Electric Cycle
#1
Start power from Battery
Into Inverter 12 V to 120 V
Inverter to Heat Controller
To 120V Electric Heater
Thermo couple controls heat with Heat controller
Heater heats Heat Plate
Battery provides power For Starter to turn over engine
And provides power to the injectors
Alternator or Generator draws power from the crank
To keep the battery charged and provides power to the
Rest of the system
Electric cycle starts over again except for the starter
The Hydro-Electric engine Coolant cycle
# 1 #2
Coolant Coolant reaches break even
Point of 106 Degrees
Electric Pump Between 106 Degrees and 190
Degrees 1% to 40% Free Energy
Injectors Coolant Cycles starts over again
Coolant sprayed on Heat plate
Steam
Steam expands
Piston moves down
Crank rotates
Exhausts valve opens
Piston moves up
Exhausts
Steam move through one way Check Valve
Out of the cylinder only
Steam moves through exhausts pipe
Coolant condenses
Heat transfers to the rest of the coolant
Coolant raises to a temp of - 40 to 190 degrees
Hydro-Electric Engine Mechanical
Cycle
#1
Piston just past top dead center
Steam Expands moving piston down and turning crank and Flywheel
Piston moves past Bottom Dead Center
Exhaust Valve opens
Piston moves up steam is pushed out
Valve closes
Steam passes through Check Valve
Cycle starts over
Hydroelectric Engine
By Jason A. Voigt
There are three major parts to the engine
Electric
Water/coolant/stream
Mechanical
Electric
It starts with Batteries to start warming the heat plate
This heat plate is on top of the cylinders of the block and under the cylinder head
This plate can be made of steal or any materiel that can transfer heat
This can also be inserts in an insulated material
The heat in the plate comes from cartridge heaters 120 volt that can reach 300 deg
Or higher so the heater can keep up with heat demand without dropping below 212
Degrees. The power comes from the battery than into an inverter witch step the power from 12V dc to 120V ac it is than ran through a temp control and thermo couple to control the heat. The Cartridge heater witch makes the heat. There is also an alternator or a generator to draw power off the crank to recharge the electrical system. Once the heat plate is up to temperature, the heater is intermittent to keep up with heat loss. There is also a starter to start the engine turning over.
Water/Coolant/Steam
The coolant system in the engine is where the water and coolant are normally used to collect heat from the engine and dissipate it. I this design it is used feed coolant to the fuel injectors in the cylinder head that are aimed at the heat plate to create steam on demand in the cylinder. Water to steam has an expansion rate of 1500 to 1 this expansion is what pushes the piston down. When the piston comes back up from inertial force the coolant is exhausted to the to the exhaust manifold and the exhaust pipe that has a one way check valve so the coolant steam can only travel out of the engine. The exhaust pipe that is connected to a radiator to complete the loop back to the coolant system. Where the steam condenses back to coolant. This also warms the coolant so it takes less energy to heat it the next time around up to the temperature of the thermostat. So in short, the energy used in the engine is stored as heat. So when the engine reaches operating temperature of 190 degrees it only take 22 degrees of temperature to reach 212 degrees this make the efficiency of the engine greater.
To push the piston down with steam. There is also a radator cap set at 200 degrees
So the engine can release energy keeping the engine safe if the thermostat false
Mechanical
The piston moves past top dead center. Coolant injects, steam, pushes the piston down.
And The flywheel on the engine rotates. At bottom dead center the exhausts valve opens moves the piston up pushing the steam out to the exhaust. The cam is on a one to one basis with the crank so every rotation is power and exhaust. There is an oil system to lubricate the engines moving parts.
Science news on Phys.org
ummmm...interesting. :rolleyes:
Physics Forums is not the place to post personal theories that have no experimental basis.
  • · Replies 26 ·
