| Thread Closed |
Diffraction: how to know the amount of slits from a diffraction pattern? |
Share Thread | Thread Tools |
| May12-10, 02:43 AM | #1 |
There are at least two different situations. If you have N-2 middle minimums, the amount of slits is N. Please, see the bottom left picture. The case with no such thing is the question about. How can I determine the amount of slits with the other cases? Please, see the other pictures in the link. 2. Relevant equations [tex]a sin(\theta) = n \lambda[/tex] where a is the width of the separtion of two side-by-side slits. Intensity formula with angle: [tex]I = I_{0} \left[ \frac{sin \left( \pi b sin \left( \frac{\theta}{\lambda} \right) \right) }{\pi b sin \left( \frac{\theta}{\lambda}} \right) \right]^{2} \left[\frac{sin\left(N \pi a sin\left(\frac{\theta}{\lambda}\right)\right)}{sin \left( \pi a sin\left( \frac{\theta}{\lambda}}\right) \right) \right]^{2}[/tex] 3. The attempt at a solution If you have 2 slits, then you have 5 main maximums. My proposal that the amount of maximums is 2N+1, where N is the amount of slits was rejected, by my teacher. You can see that it is not the case from the Wolfram link above. Then I tried to delve into the wave function but I am really lost with it. Cannot see how it helps in finding the the number of slits. |
| Thread Closed |
| Tags |
| diffraction, fraunhofer, slits |
| Thread Tools | |
Similar Threads for: Diffraction: how to know the amount of slits from a diffraction pattern?
| Spacing between slits in a diffraction grating w/o known wavelength | Introductory Physics Homework | 1 | ||
| Diffraction pattern | Advanced Physics Homework | 1 | ||
| Slits per cm on diffraction grating | Introductory Physics Homework | 5 | ||
| Trig problems (Interference/diffraction and slits)) | Introductory Physics Homework | 3 | ||
| Multiple slits diffraction | Introductory Physics Homework | 2 | ||
