Weightlessness in the Center of The Earth?
The discussion centers around the concept of experiencing weightlessness at the center of the Earth, exploring gravitational effects as one digs a tunnel towards the center. Participants examine theoretical implications, gravitational forces, and the impact of Earth's non-uniform density.
  • Some participants propose that at the center of the Earth, gravitational pull is equal in all directions, leading to a state of weightlessness, assuming the tunnel is filled behind the individual.
  • Others argue that as one digs into the Earth, the gravitational pull is influenced by the mass below, which decreases as one approaches the center, becoming zero at the center.
  • It is noted that the assumption of uniform density is critical; if the Earth is not uniform, a non-zero net force may exist due to uneven mass distribution.
  • Some participants mention that the density of the Earth varies with depth, suggesting that one might experience a slight increase in weight before reaching the center.
  • A participant raises a question about the potential effects of the Earth's magnetic field on gravitational experiences, proposing an analogy with a ping-pong ball in a blower.
  • There is a discussion about the Newtonian logic of concentric spherical shells and its applicability in the context of a density gradient within the Earth.
  • Some participants challenge the idea that gravitational effects would be the same inside a hypothetical Dyson sphere, emphasizing that the presence of mass alters gravitational forces.
Participants express multiple competing views regarding the gravitational effects experienced while digging towards the center of the Earth. There is no consensus on whether one would experience weightlessness or an increase in weight due to varying density.
The discussion highlights limitations in assumptions about uniform density and gravitational effects, as well as the implications of Earth's shape and mass distribution on gravitational experiences.
hexrd
Is it true that if you dig a tunnel to the center of the Earth you will experience weightlessness? I heard that you will get heavier then become weightless.
Astronomy news on Phys.org
Yes, at the center of the earth, the gravitational pull due to the mass around you is equal in every direction and so you would be "weightless". (That's assuming you fill in the hole behind you. Otherwise there would be a miniscule pull in the direction opposite the hole.
Your second statement "you will get heavier" is NOT true. As you dig into the earth, the gravitational pull will be due to the mass of Earth still BELOW you. The mass above you will "cancel". Since the mass below you is proportional to r3 and the gravitational force is proportional to 1/r2, the net force is proportional to r3/r2= r. The force on you will decrease as r becomes smaller, becoming 0 when r= 0.
HallsofIvy said:
Yes, at the center of the earth, the gravitational pull due to the mass around you is equal in every direction and so you would be "weightless". (That's assuming you fill in the hole behind you. Otherwise there would be a miniscule pull in the direction opposite the hole.)
This statement is only valid if the Earth is a uniform shape, such as a perfect sphere. Earth is actually an oblate spheroid with the equatorial radius approximately 6378.5 km and the polar radius approximately 6356.9 km and its shape is not uniform. Without an even distrubtion of mass surrounding the individual, a nonzero net force would be present pointing in the direction of the greatest distribution of mass.
The other thing to consider is that the density of the Earth isn't uniform as you go down. You're getting closer to the 'massier' stuff, while the lighter crust gets cancelled.
So you'll get heavier, but not significantly so.
The Newtonian logic of concentric spherical shells still works with a density gradient.
Just a thought. If the core of the planet where nickel surrounded by a layer of molten magma (stereotype?), wouldn't the magnetic field interfere with a gravitational effect? and with that pretense a person or object would be sort of like a ping-pong ball at the end of a blower? the result being batted around resulting in no gravitationally neutral spot?
That doesn't make sense to me.
If that is true, then if you were inside a hypothetical Dyson sphere, the gravitational force of the sun would be the same whether you were right near the sun or out near the sphere itself. Right?
No. The "Newtonian logic of concentric spherical shells" that SelfAdjoint refers to is the fact (proved by Newton) that a uniform spherical shell of mass has a gravitational field that is zero everywhere inside the shell.
Of course that's only true if the shell is empty. :smile: Inside a Dyson sphere you have the sun, which exerts its usual gravitational force.
Yes, but SelfAdjoint said that if you've got a density gradient inside the shell the thing works.
He said that in response to my post that you will get a little heavier first.
If there is a light, thin crust, and a heavier mantle, then when you go down under the crust before you start to dig in the mantle you will first get a (very little) bit heavier as you are now closer to the heavier stuff while having the lighter stuff get zero'd out.
I suspect SelfAdjoint was just making it clear that the argument for there being zero gravity at the center of the Earth (the original question), which is based on Newton's shells, still works even if the Earth's density depends on the distance from the center. I don't think he was disputing your statement.
Did my statement about the Dyson sphere make sense?
Yes. You were making the same point which I was trying make by analogy. If you've got a Dyson's sphere, your distance from the sun does affect the gravitational force.
Similarly, if you dig through a lighter portion of the crust, getting closer to a heavier section after a discontinuity (which is what happens when you get to the mantle), your weight would increase a small amount before it starts to decrease.
  • · Replies 21 ·
  • · Replies 32 ·
  • · Replies 47 ·
12K
  • · Replies 36 ·
  • · Replies 27 ·
