Kinetic Energy vs Gravitational Potential Energy Experiment
The discussion revolves around an experiment comparing kinetic energy and gravitational potential energy, specifically involving an inclined plane setup. Participants are examining the methodology, results, and interpretations of the experiment.
  • Participants question the accuracy of the method and results, noting potential discrepancies in the relationship between kinetic and potential energy. There is a focus on the implications of observed data and the significance of a term that appears in the equations presented.
The discussion is ongoing, with participants providing feedback on the experiment's setup and results. Some guidance has been offered regarding the interpretation of data and the nature of experimental errors, while multiple interpretations of the results are being explored.
There are indications of potential errors in measurements, particularly concerning time, and participants are considering the impact of these errors on the expected outcomes of the experiment.
yeah:)
Here is a summary, written by me, of an experiment I carried out:
Is the method correct (if you recognise the experiment)? Are the results and conclusion correct (do any of the figures/calculations seem significantly wrong)? Is there anything more I could say for the conclusion? Any ideas would be much appreciated!
For one thing, it's an inclined plane (not plain).
Anything else related to the Physics itself?
I can't quite visualize the experiment, so I don't think I can make any meaningful comment on the physics in it (which is why I just pointed out the misspelling). I mean, your formulas are correct and the numbers look reasonable.
Actually... on a second look, one thing that did catch my eye is that the difference between kinetic energy and potential energy (or your % error, if you prefer to think of it that way) gets larger the more mass you use. To me, that could indicate that maybe the potential energy lost is actually not equal to the kinetic energy gained. I mean, of course I know that it is supposed to be equal, and so do you I presume, but your data don't quite back up that conclusion. What you seem to have found is a relationship more like
[tex]mgh = \frac{1}{2}mv^2 - \alpha (m - m_0)[/tex]
and if it were me, I'd be suspicious enough to look into what the origin of that [itex]\alpha[/itex] term might have been.
Could it be the times are wrong? What would the ideal results be?
Hey, you're the one who did the experiment :wink: How would I know if the times are wrong?
And think about it, you know what the ideal result should be... keep in mind, though, that in experimental science just because your data doesn't back up the ideal/expected result, it doesn't necessarily mean you screwed up. There are sources of error that you can't control that make your data vary a bit from what you expect, but it's your responsibility to recognize, and ideally account for, any variations you find.
