Angle of Deviation - 2 Mirrors
In summary, the question is how the angle of deviation depends on the angle between two mirrors and the Law of Reflection is a key concept to understanding this. The angle of deviation is the measure of how much the light has strayed from its initial straight-line path. It is equal to the reflected angle compared to the incident angle. The number of mirrors and their arrangement do not affect the angle of deviation. In the first image provided, the angle of deviation is 180 degrees, while in the second image it is 0 degrees. Thanks to user Rajrendra Lakshmanapathy Bhat for providing helpful guidance.
XigmaTek
Hi, my teacher asked me to conduct an experiment on the question "How does the angle of deviation depend upon the angle between two mirrors?" - We weren't given much else on the topic. I know how to find the angle between two mirrors, but finding the angle of deviation of the light ray is what I'm lost at.
Law of Reflection?
I came up with my own solutions to try and find a method to calculate angle of deviation. Anyway, here is the diagram which I created to hopefully shed some light on the situation
[PLAIN]http://img696.imageshack.us/img696/6097/phys1k.jpg
As you can see, θi is the incoming light ray (just a name for it...) and θf is the final, or outgoing ray. Now, as seen, θf (the outgoing ray) has been reflected straight back in the same direction as the original ray. Do I just say the angle of deviation is 360, or does it have something to do with the angles made at the mirrors (m1 and M2). θ1+θ2 = 180, so is that the angle of deviation?
___________________________
Now in the image below (which I again made, myself), if you only adjust one of the mirrors (I changed M2), you get a different story. Now, as seen the outgoing light ray continues on in the same direction as the incoming light ray. Is the Angle of Deviation Zero degrees here? Or do I add up the angles between M1 and M2? Which gives me 180? But how can the Angle of Deviation be 180 when the light ray simply keeps going on in the same direction?
[PLAIN]http://img404.imageshack.us/img404/7955/phys2.jpg
I'm lost as to how to find the Angle of Deviation of a light ray after reflection of 2 mirrors...
Please help. Thanks !
A ray of light that is incident on to the surface of a plane-mirror is reflected with the angle of incidence equal to the angle of reflection. Suppose that the ray had continued, through the mirror, in a straight line it would make an angle θ with the surface of the mirror. The total angle between the straight-line path and the reflected ray is twice the angle of incidence. This is called the deviation of the light and measures the angle at which the light has strayed from its initial straight-line path.
http://www.splung.com/content/sid/4/page/planemirrors
If that's the case then, how do I apply that to 2 mirrors? I understand that concept for 1 mirror... But how to apply it to 2, I'm lost.
Angle of deviation is the angle of reflected ray with respect to the incident ray. It is nothing to do with the number of the mirrors and their arrangement in between.
Now you can find out the result.
So with my first image posted up, if I compare the reflected ray to the incoming ray, Is the angle of deviation 360*? and for the second image is just simply zero*?
In the first case the angle of deviation is 180*. It can't be more than 180*. The ray of light is not a rotating vector.
Thanks mr. Rajrendra Lakshmanapathy Bhat... your help has been great. So, from this, I take it you just compare the two angles together (incident & final-reflected rays) and see the angle made between them... So for my second image, the Angle of Deviation is 0*, right? Again, thanks for the help mate
1. What is the angle of deviation in a two-mirror setup?
The angle of deviation in a two-mirror setup is the angle between the incident ray and the final reflected ray after passing through the two mirrors. It is also referred to as the total angular deviation.
2. How is the angle of deviation affected by the angle of incidence?
The angle of deviation is directly affected by the angle of incidence. As the angle of incidence increases, the angle of deviation also increases. This is because a larger angle of incidence results in a greater change in direction for the reflected ray.
3. What is the relationship between the angle of deviation and the angle between the two mirrors?
The angle of deviation is inversely proportional to the angle between the two mirrors. As the angle between the mirrors increases, the angle of deviation decreases. This is because a larger angle between the mirrors allows for a greater change in direction for the reflected ray, resulting in a smaller angle of deviation.
4. How does the number of reflections affect the angle of deviation?
The angle of deviation increases with each additional reflection in a two-mirror setup. This is because each reflection causes a slight change in direction for the incident ray, resulting in a larger overall change in direction and a larger angle of deviation.
5. Can the angle of deviation be negative?
Yes, the angle of deviation can be negative in a two-mirror setup. This occurs when the final reflected ray is on the opposite side of the incident ray from the initial direction. In this case, the angle of deviation is measured in the opposite direction from the incident ray.
