Solution stoichometry, attempted ANSWER IS WRONG, can anyone fix answer
  • Thread starter Thread starter land_of_ice
The concentration of an unknown H3PO4 solution was determined to be 0.293 M after reacting with 110 mL of 0.120 M KOH. The initial approach incorrectly calculated the molarity by misapplying the mole-to-mole conversion and not properly accounting for the stoichiometry of the reaction H3PO4 + 3KOH → 3H2O + K3PO4. The correct method involves recognizing that 15 mL of H3PO4 corresponds to 0.015 L, and using the stoichiometric ratio of 1 mole of H3PO4 to 3 moles of KOH to find the accurate concentration.
  • Understanding of acid-base titration principles
  • Knowledge of molarity calculations
  • Familiarity with stoichiometric relationships in chemical reactions
  • Ability to convert between milliliters and liters
  • Study the concept of titration curves and their applications in acid-base chemistry
  • Learn about the dissociation reactions of phosphoric acid (H3PO4)
  • Explore advanced stoichiometry problems involving multiple reactants
  • Review the principles of molarity and how to calculate concentrations in titrations
Chemistry students, educators, and laboratory technicians involved in acid-base titrations and stoichiometric calculations.
land_of_ice
A 15.0 mL sample of an unknown H3PO4 solution requires 110 mL of 0.120 M KOH to completely react with the H3PO4 according the following reaction.
H3PO4 + 3KOH --------> 3H20 + K3PO4
What was the concentration of the unknown H3PO4 solution?
______________________________________…
This SEEMED correct way to start problem, as it turns out this is not how to set up the problem, (attempt at doing the problem) : 15mL converted that to L , got 0.015 L, then multiplied that by .12 moles of the solute KOH divided by 1 Liter of the solution H3PO4, used the mole to mole conversion 3 moles of KOH to every 1 mole of H3PO4 and got the wrong answer. It's supposed to be
.293 Molarity.
.293 Molarity.
You have to do the three dissociation reactions separately.
15 mL is the volume of acid, not base.
12K
  • · Replies 18 ·
23K
