How Is Total Energy Derived in a Special Relativity Collision?
The discussion revolves around a collision problem in the context of special relativity, specifically focusing on deriving the total energy of two particles in their center of mass frame. The original poster presents a scenario involving a particle with rest mass M colliding with another particle of rest mass m at rest, aiming to show a relationship involving their total energies.
  • Mixed
  • The original poster attempts to apply conservation of four momentum and relate energies through gamma factors, but expresses difficulty in eliminating variables to derive the total energy.
  • Some participants suggest alternative approaches, such as using the original frame instead of the center-of-mass frame and focusing on energy and momentum directly.
  • There are discussions about the interpretation of energy, including the distinction between relativistic and Newtonian kinetic energy, and the implications of using approximations.
  • One participant introduces the concept of four-momenta and the use of specific equations related to energy and momentum in relativistic contexts.
The discussion is ongoing, with participants exploring different methods and interpretations. Some guidance has been offered regarding alternative approaches, but there is no explicit consensus on a single method or solution. Participants are actively questioning assumptions and clarifying concepts related to the problem.
There is mention of official solutions that utilize different methods, which raises questions about their comprehensiveness and clarity. Participants are also navigating the complexities of relativistic equations and the implications of using four-vectors in their analysis.
astoria
A particle of rest mass M and total energy E collides with a particle of rest m at rest. Show that the sum E' of the total energies of the two particles in the frame at which their centre of mass is at rest is given by
(E')^2=(M^2+m^2)c^4+2Emc^2
3. The attempt at solution
I'll denote particle of rest mass M as having velocity v and particle of rest mass m as having velocity w and the relevant gammas as G(v), G(w)
E=Mc^2
Conservation of four momentum implies:
E'=G(v)Mc^2+G(w)mc^2
0=G(v)Mv+G(w)mw (where v and w are vectors)
G(v)Mv=-G(w)mw
(G(v)Mv)^2=(G(w)mw)^2 (taking modulus squared of both sides)
M^2(G(v)^2-1)=m^2(G(w)^2-1) (as G(u)^2=c^2(G(u)^2-1)
I can't see how to eliminate both G(v) and G(w) and get an answer for E', I need another equation.
hmmm. Thats not quite the way I'd do things (I get to an answer pretty close to the right one but not quite)
E (before the collision) = E' (after)
So use the fact that:
E = kinetic energy + rest mass.
Not sure why but I get the same solution as yours: in my final answer I have a [tex]\gamma M[/tex]. In the first bracket. The 2Emc^2 part comes out right though. Maybe you can find if/where I made a mistake.
I may be misunderstanding what you mean but I think what you are saying is that the energy is the sum of the Newtonian kinetic energy and mc^2 (i.e E=(mc^2+1/2mv^2))
This is only true if we take gamma as equal to 1+v^2/2c^2 and ignore the higher order terms.
Try working in the original frame instead of the center-of-mass frame since E appears in your answer, and use E's and p's as your variables instead of writing them out in terms of gammas, masses, and velocities.
A very useful equation in these types of problems is E2-(pc)2=(mc2)2.
Thanks, that came out fine :)
I've had a look at the official solutions (which are only outline) and it seems to do it a completely different way, using g(P+Q,V) etc
I've never seen this sort of problem done like that before, is it easier? unfortunately it's not comprehensively explained, how would I set it up?
I have no idea. You'd have to explain it a bit more before I could tell what they did.
Essentially it just says:
The four momenta of the particles are P=(E/c,p) and Q=m(c,0) in the given inertial frame. In centre of mass frame the four velocity V of the centre of mass decomposes as (c,0) and P+Q decomposes as (E'/c,0). Moreover g(V,V)=c^2 Therefore:
V=c(P+Q)/sqrt(g(P+Q,P+Q)) E'=g(V,P+Q)
Now use E'^2=(c^2)g(P+Q,P+Q)
I'm not sure why the solution bothers working with the four-velocity. You can see directly from P+Q=(E'/c,0), that E'2=c2(P+Q)2. It's pretty much the same solution otherwise.
Having read more solutions of this form, am I right to assume that if V,W are the four velocities in ICS 1 and V' W' are the four velocities of two particles in ICS 2g(V,W)=g(V',W')?
Yes, because the product of two four-vectors is invariant.
  • · Replies 38 ·
