Electric Field between two opposite, gaussian distributed charged spheres
The discussion focuses on calculating the electric field between two overlapping spheres with Gaussian charge distributions, specifically using the equations for uniform charge distributions. The participants highlight the complexity of integrating the charge densities, ρ₊ and ρ₋, to find the electric field at a point P = (x,y,z). The integration involves summing the contributions from both charge distributions, which complicates the calculation due to the overlap of the spheres. The goal is to model this electric field to analyze a harmonic oscillator system involving an electron sphere oscillating around a stationary ion sphere.
  • Understanding of electric fields and charge distributions
  • Familiarity with Gaussian functions and their properties
  • Knowledge of integration techniques in three-dimensional space
  • Basic concepts of harmonic oscillators in physics
  • Study the derivation of electric fields from Gaussian charge distributions
  • Learn about numerical integration techniques for complex charge distributions
  • Research harmonic oscillators and their mathematical modeling
  • Explore relevant physics textbooks or articles on electrostatics and charge interactions
Physicists, electrical engineers, and students studying electrostatics, particularly those interested in advanced topics involving charge distributions and harmonic oscillators.
Nick White
Hi,
I understand how to get the electric field between two spheres of uniform charge,
[tex] \vec{E} = \frac{\rho \vec{d}}{3 \epsilon_0}[/tex]
which is simplified because at a point [tex]\vec{r}[/tex], the vectors from each charge center combine to give the distance, [tex]\vec{d}[/tex], between centers (since [tex]\rho[/tex]'s can be factored).
So far, calculating this for two overlapping spheres of gaussian charge distribution seems non-trivial since you can't make this factorization and simply obtain an expression proportional to [tex]\vec{d}[/tex]...
Am I correct with the complexity of this problem, or is there some way more efficient to approach this problem?
I hope to use this electric field to model a harmonic oscillator (electron sphere oscillating around stationary ion sphere) and find a frequency...
Thanks
I think you have first to calculate which is the total rho of you 3D distribution.
This seems to be the sum of the two rho's you presented. After that I guess you will have to use integration over the whole space to get the field at point P = (x,y,z).
Best Regards,
DaTario
Best Regards,
DaTario
Thanks for the response DaTario.
I've started with that method - finding the field at a point P = (x,y,z) (point [tex]\vex{r}[/tex] in spherical) by integrating the charge from the positive distribution [tex]\rho_{+}=\rho_{0}exp(-(r^{2})/(2\sigma^{2}))[/tex] and then the negative distribution [tex]\rho_{-}=\rho_{0}exp(-(r-d)^{2}/(2\sigma^{2})), assuming [tex]d[/tex] is the displacement of the negative charge center along the z-axis for convenience, but i think it get hairy because these end up being factors for the vectors [tex]\vec{r}_{+}[/tex] and [tex]\vec{r}_{-}[/tex] when you sum the electric fields to get the total, in the overlap.<br /> <br /> I was wondering if there's maybe a book problem like this, or even an article i could refer to...<br /> <br /> NW[/tex]
  • · Replies 29 ·
