| Thread Closed |
Electrical Voltage, a appliance problem |
Share Thread | Thread Tools |
| May17-10, 04:01 AM | #1 |
Anyway can you please help me out with the following? 240V , 50 Hz electrical appliance is rated at 2 kW. It has a lagging power factor of 0.7 (a) What is appliances power factor when it is used on a 60Hz supply. (b) What is supply voltage required to maintain appliance at its rated power when operated off a 60 Hz supply? 2. The attempt at a solution No idea..! Can you suggest some relevant equations and guidance? Thanks in advance |
| May17-10, 09:02 AM | #2 |
First find Z of the load using the relation P=V^2/Z. Then using the given power factor you can find the reactance X=Zsin(theta). Let this be X1. Now find new X (X2) for 60 Hz. Remember X is directly proportional to frequency for a lagging circuit since it is inductive. From X2 you can calculate the parameters you want to know.
| May17-10, 03:40 PM | #3 |
Hello, can you be bit more explanatory?
i am not getting anything ! |
| May17-10, 11:58 PM | #4 |
You are asked to find pf on 60 Hz. You may remember that the impedance of the load Z=R+jX, where X is positive for inductive loads i.e., lagging pf and only X is dependent on frequency. Also pf=tan(X/R). Now if you change frequency of supply X changes proportionately. You know X=2*pi*f*L for inductive load. So for change in frequency from f1=50Hz to f2=60Hz , we have X2/X1=f2/f1. The first thing you have to do is find X1 i.e., X at 50 Hz using relations I mentioned earlier (Note pf=cos(theta) and so you can find theta). Then find X2 and from this since R is unchanged, you can find new pf.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Electrical Voltage, a appliance problem
| Node Voltage analysis- electrical engineering | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Voltage dividers and electrical ground | Electrical Engineering | 1 | ||
| electrical generator- governing laws for RPM to voltage output | Electrical Engineering | 6 | ||
| Intro Electrical Engineering Voltage Regulator | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Maximum safe level of Electrical Voltage | Electrical Engineering | 18 | ||
