- 19,917
- 10,945
Have your own personal blogs
https://www.physicsforums.com/journal.php
jimmy p said:...and the point is? is it like personal grafitti or something?
hehe, I will just write everything in DutchMoonbear said:Though, I'm wondering, when a journal entry is marked private, can Greg still read it? Is this a way for Greg to go journal snooping?![]()
Monique said:hehe, I will just write everything in Dutch![]()
Doc Al said:Question for Greg: Can a given journal entry be edited indefinitely? Or is there a time limit (like for ordinary post--which can't be edited after a 20 hour or so window). I'm thinking that if someone wanted to post an essay on a topic--they might want to keep it up to date by regular tweaking.
Yes, but these don't seem to be available on the journal pages.enigma said:plover,
If you click on the poster's name to the left of the post it pulls up a drop-down menu with the options to view the profile, send a PM, send email, find posts by the person, and add to your buddy list.
plover said:What does "lock journal" do? Make the whole journal inaccessible to other people? Or just prevent comments?
plover said:Are the two occurences of "private" in "0 private are private" intentional? If so what does the phrase mean?
It makes the journal unviewable by the author? That seems odd.The_Professional said:It makes your journal entry inaccessible for viewing and comments from you and other people. In essence, it closes it.
Yes, that much is clear. However, "0 entries are private ", or simply "0 private", would indicate as much. As it stands, the intention of the wording is unclear.It means that the person hasn't designated any journal entry as private. If you make a journal entry and choose 'Private' you will be the only person to view it. Most journal entries are 'Public' by default unless you choose 'Private'.
plover said:It makes the journal unviewable by the author? That seems odd.
plover said:Yes, that much is clear. However, "0 entries are private ", or simply "0 private", would indicate as much. As it stands, the intention of the wording is unclear.
Ok, I tried it.The_Professional said:When you lock your journal, yes. It's a feature. Try making a journal entry and then lock it.
The actual meaning of the line is probably not unclear -- it is the purpose of the syntax "0 private are private" that is unclear. (Adding an entry just produces "1 private are private", which is no better.) The syntax appears to be just a normal typing error, in which case there is no problem. However, if the syntax is not a mistake, then its purpose is not obvious. In any event, it's not particularly important.How is it unclear? it simply means there's no private entry :)
