mysearch
On the basis that Larmor’s formula specifies the energy/power radiated from an accelerated charge, provided v<<c, I was assuming that this equation must also characterised the energy power transferred to the EM waves/photons emitted by the accelerated charge. I know Larmor’s work predates the idea of a photon and quantised energy, but looking at the derivation of Larmor’s formula raised some questions, which I was hoping somebody might be able to clarify.
First, the derivation of Larmor’s formula I have been studying exists within section 4.2/page 31 of Daniel Schroeder’s pdf document, which can be access via the following link: http://physics.weber.edu/schroeder/mrr/MRRnotes.pdf . While I am not totally sure whether this approach is generally accepted, it seems to be based on the idea that an accelerating charge causes a ‘kink’ in the electric field lines, such that the net electric field (E) has both a radial (Er) and transverse (Et) component. The strength of these components is given on page 33 as follows:
[1] [tex]Er=\frac{q}{ 4 \pi \epsilon_0 R^2}[/tex]
[2] [tex]Et=\frac{qa*sin \theta}{ 4 \pi \epsilon_0 c^2R}[/tex]
These equations show different proportionality with respect to the radius [R] such that (Et) starts to dominate as [R] increases. So my first question is whether these equations are reflective of the idea of ‘near’ and ‘far’ field definitions?
Over the next few page (p34/35) of the Daniel Schroeder’s document, he derives Larmor’s formula starting with:
[3] [tex]Energy-per-unit-volume=\frac{\epsilon_0 E^2}{2}[/tex]
Equation [2] is substituted into [3] to give:
[4] [tex]Energy-per-unit-volume=\frac{q^2a^2 sin^2 \theta}{32 \pi \epsilon_0 c^4 R^2}[/tex]
This equation is only accounting for the electric field, i.e. no initial consideration of the magnetic field, which eventually doubles the energy. However, the point I want to clarify is that the energy/unit volume appears to be still subject to the inverse square law. Only after multiplying equation [4] by the volume of the spherical shell, i.e. [tex]4 \pi R^2 * thickness[/tex], in which (Et) exists, do we eventually arrive at Larmor’s formula.
[5] [tex]Power-radiated=\frac{q^2a^2}{ 6 \pi \epsilon_0 c^3}[/tex]
What is unclear to me is whether this equation is representative of energy/power radiated by EM wave(s) in all directions, while noting the directionality associated with the [tex]sin^2 \theta[/tex] term in [4]. For while the total radiated energy in the spherical shell remains constant, the energy density associated with (Et), as defined by [4], would seem to diminish as the (Et) kink propagates outwards to a larger radius [R]. As such, I don’t see how this equation really reflects the energy of a EM wave or photon propagating without loss in a vacuum.
A photon as a discrete quantum of energy [E=hf] could define a lossless container of propagating energy, but presumably requires the distribution spread of the EM wave to be aggregated by a statistical distribution, which I am assuming is the subject of quantum theory rather than classical fields. So how did classical theory explain how light travels from the stars without loss?
Thanks
Thanks
