Integrating over Region A: Calculating the Volume of a Cone
The discussion focuses on calculating the volume of a region A bounded by two spheres, defined by the equations x² + y² + z² = 1 and x² + y² + z² = 4, above the plane z = 0 and within the cone defined by z² = x² + y². Participants are tasked with expressing the triple integral ∫∫∫_A f(x,y,z) dxdydz in a specific form and finding the volume of region A. The use of spherical coordinates is recommended for simplifying the volume calculation.
  • Understanding of triple integrals in calculus
  • Familiarity with spherical coordinates
  • Knowledge of the equations of spheres and cones
  • Ability to visualize geometric shapes in three-dimensional space
  • Study the derivation of triple integrals in spherical coordinates
  • Learn how to visualize and sketch conic sections in three dimensions
  • Explore the application of the Divergence Theorem in volume calculations
  • Investigate methods for determining the volume of bounded regions in calculus
Students studying multivariable calculus, mathematicians interested in geometric volumes, and educators teaching integration techniques in three dimensions.
WannaBe22
Let A be the region that in space bounded by the balls:
[tex]x^2 +y^2 + z^2 =1[/tex] , [tex]x^2 +y^2 +z^2 =4[/tex] , above the plane [tex]z=0[/tex] and inside the cone [tex]z^2 = x^2 +y^2[/tex].
A. Write the integral [tex]\int \int \int_{A} f(x,y,z) dxdydz[/tex] in the form:
[tex]\int \int_{E} (\int_{g^1(x,y)}^{g^2(x,y)} f(x,y,z) dz) dxdy[/tex] when :
[tex]A=( (x,y,z) | (x,y) \in E, g^1(x,y) \le z \le g^2(x,y) )[/tex] ...
B. Find the volume of A (not necessarily using part A).
Hope you'll be able to help me in this... I think the main problem is that I can't figure out how A looks like... There is also a hint that one of the functions g1 or g2 should be defined at a split region... I can't figure out how this cone looks like and how I can describe A as equations ...
Thanks in advance!
so you have a sphere of radius 1 & and a sphere of radius 2...
to visualise the cone z^2 = y^2 + x^2, consider the coordinate planes y = 0 and x = 0, these will be vertical slices through the cone - what is the equation of the curve in each plane.
no consider a slice for a given z, you have y^2 + x^2 = z^2, which is an equation for a circle in x & y - what is the radius?
the 2nd part will be much easier to do in spherical coordinates...
  • · Replies 19 ·
