Expanding and Substituting: Solving (1-3x)^{\frac{1}{3}}
  • Thread starter Thread starter thereddevils
    Expanding
The problem involves expanding the expression (1-3x)^{\frac{1}{3}} in ascending powers of x up to the term x^3 and finding an appropriate substitution for x to demonstrate that \sqrt[3]{3}=\frac{33809}{19683}.
  • Exploratory, Assumption checking
  • Participants discuss the expansion of the expression and the validity range for x. Questions arise about finding a suitable substitution for x without guessing, and whether the proposed substitutions lead to the desired result.
Some participants suggest potential substitutions for x based on the requirement to find the cube root of 3, while others express concerns about the validity of these substitutions given the range for x. There is no explicit consensus on the best approach yet.
Participants note the range for x must satisfy -1/3 < x < 1/3 for the expansion to be valid, and there is uncertainty regarding the relationship between the cube root of 3 and the fraction 33809/19683.
thereddevils
Expand [tex](1-3x)^{\frac{1}{3}}[/tex] in ascending power of x , up to the term x^3 . By using an appropriate substitution for x , show that [tex]\sqrt[3]3=\frac{33809}{19683}[/tex]
the expansion would be 1-x-x^2-(5/3)x^3 and the range of x whixh make this expansion valid is |-3x|<1/3 .
My question is how do i find this appropriate substitution for x ? Instead the guessing way , is there a proper way ?
Well, since you have [itex](1- 3x)^{1/3}[/itex] and want [itex](3)^{1/3}[/itex] you probably want to make 1- 3x= 3. Solve that for x.
i don think so because -1/3<x<1/3 for this expansion to be valid .
Hi thereddevils
Maybe this method can be applied. Since we want to find the cube root and the range for x is -1/3<x<1/3 , we can deduce that (1-3x) should be fraction.
So, the denominator should be a number that is integer and has a cube root, which is also integer , such as 8, 27, etc
Now we can try (1-3x) = 3/8 or (1-3x) = 3/27 , etc..
But cube root of 3 is not 33809 / 19683.
33809 / 19683 is closer to square root of 3. Maybe you can re-check the question :smile:
  • · Replies 24 ·
