| Thread Closed |
Irrational number approximation by a rational number |
Share Thread | Thread Tools |
| May20-10, 06:40 AM | #1 |
Is there a way ( a theorem ) to find a rational number for a given irrational number such that it is an approximation to it to the required decimal places of accuracy. For example 22/7 is an approximate for pi for 2 decimal places.
| May20-10, 06:41 AM | #2 |
best rational approximation (via continued fractions)
| May20-10, 04:06 PM | #3 |
Recognitions:
There is always the trivial solution. Write out the decimal expansion for the irrational to the required number (plus one) of places. Then truncate (or round). This rational number will satisfy the criterion.
| May20-10, 05:26 PM | #4 |
Recognitions:
^That tends to give big denominators, how distasteful.
| May21-10, 04:50 PM | #5 |
Recognitions:
| May21-10, 08:32 PM | #6 |
Mathematica has the command "Rationalize" to do this. I think it uses continued fractions as Xitami mentioned above. If you have more than one irrational number then you can ask if there is an approximate relation between them involving rational numbers. That problem can be efficiently solved using the LLL algorithm:
http://en.wikipedia.org/wiki/Lenstra...tion_algorithm |
| Jun21-10, 04:30 AM | #7 |
Write down the decimal expansion to the accurate number of digits required+1 and make the penultimate digit to round figure and then convert it to fraction by dividing it by 10 to power number of decimal digits.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Irrational number approximation by a rational number
| Prove that between any two rational numbers there is at least one irrational number.. | General Math | 26 | ||
| rational/irrational number | General Math | 12 | ||
| For every rational number, there exists sum of two irrational numbers... | Calculus & Beyond Homework | 6 | ||
| What number is rational and irrational | General Math | 22 | ||
| Rational and Irrational Number Set proof. | Set Theory, Logic, Probability, Statistics | 4 | ||
