Solving Error Accumulation in Physics Simulation Program
The discussion revolves around the challenges of error accumulation in a physics simulation program that models gravity acting on point particles. Participants explore numerical integration methods and their implications for the accuracy of the simulation over time.
  • One participant describes their implementation of gravitational force calculations and the resulting issues with particles gaining speed and moving erratically, despite using refined equations.
  • The equations for gravitational force, acceleration, and position updates are shared, along with the code structure for the simulation.
  • Another participant suggests that the numerical integration method used for calculating velocities and positions may be the source of the error accumulation, proposing an iterative corrector method to improve results.
  • The second participant mentions that increasing the number of iterations in the correction process could lead to better convergence of the simulation results.
There is no consensus on the specific cause of the error accumulation or the best method to resolve it. Multiple approaches and suggestions are presented, indicating ongoing debate and exploration of solutions.
The discussion highlights potential limitations in the numerical integration method and the need for further refinement in the simulation approach. Specific assumptions about the accuracy of the equations and the behavior of the system over time remain unaddressed.
Kynnath
I'm trying to write a program that will simulate basic gravity on a set of point particles. The problem I'm having is the program accumulates a lot of error very quickly, the particles start gaining speed and soon they're off to weird places. I can also track how the center of mass of the system starts moving all over the palce. Which shouldn't happen.
Not sure why error grows so quickly, though. I'm using the same equations I've seen in other simulators (actually a bit more refined, which should have led to less error I thought). But still they fly off in every direction.
The equations I'm using are:
Fg = G * ( mi * mj ) / ( d(i,j)^2 )
for the force of gravity, from which I get acceleration by dividing Fg by mi for the particle i and by mj for particle j. I run this for every pair of particles.
I add up the acceleration from each interaction, and use that to modify the velocity of the particle. I also store the acceleration from the previous iteration.
v(t) = v(t-1) + ( a(t) + a(t-1) ) / 2
and from this I get the new position for the particle
p(t) = p(t-1) + ( v(t) + v(t-1) ) / 2
The code itself is
Code:
void nSistema::updateSistema1 ( )
	long double G = 0.0000000001 ;
	nLista<nVector<long double> > ainicial ; //Lista para almacenar las aceleraciones de la vuelta previa para cada objeto
	centrodemasa_.setAceleracion( nVector<long double> () ) ;
	for ( unsigned int i = 0 ; i < cuerpos_ ; ++i )
		nCuerpo * cuerpoi ( sistema_.getObjeto( i+1 ) ) ;
		if ( i == 0 ) // en la primer pasada tiene que guardarse la aceleracion previa y borrarse para calcular la nueva
			ainicial.addObjetoEnd( cuerpoi->getAceleracion() ) ;  //aceleracion previa
			cuerpoi->setAceleracion( nVector<long double> () ) ;  //setear a a 0 para el nuevo ciclo
		for ( unsigned int j = i+1 ; j < cuerpos_ ; ++j )
			nCuerpo * cuerpoj ( sistema_.getObjeto( j+1 ) ) ;
			if ( i == 0 )// en la primer pasada tiene que guardarse la aceleracion previa y borrarse para calcular la nueva
				ainicial.addObjetoEnd( cuerpoj->getAceleracion() ) ;
				cuerpoj->setAceleracion( nVector<long double> () ) ;
			nVector<long double> ij ( cuerpoj->getPosicion() - cuerpoi->getPosicion() ) ;
			long double d2 ( ij.getNorma2() ) ;
			long double d ( sqrt( d2 ) ) ; std::cout<< "d ( " << i+1 << " a " << j+1 << " ) = " << d << std::endl ;
			nVector<long double> Fg ;
			if ( d > 0.1 ) Fg = ij * G * ( cuerpoj->getMasa() * cuerpoi->getMasa() ) / ( d2 * d ) ;
			else Fg = nVector<long double> ( ) ;
			cuerpoi->setAceleracion( cuerpoi->getAceleracion() + ( Fg / cuerpoi->getMasa() ) ) ;
			cuerpoj->setAceleracion( cuerpoj->getAceleracion() - ( Fg / cuerpoj->getMasa() ) ) ;
		nVector<long double> a0 ( * ainicial.getObjeto( i+1 ) ) ;
		//updatear v de cuerpoi ;
		//nVector<long double> test ( cuerpoi->getAceleracion() ) ;
		//std::cout << "test[" << i+1 << "] : a = ( " << test.getX() << " , " << test.getY() << " , " << test.getZ() << " )" << std::endl ;
		nVector<long double> v0 ( cuerpoi->getVelocidad() ) ;
		cuerpoi->setVelocidad( v0 + ( cuerpoi->getAceleracion() + a0 ) / 2 ) ;
		//updatear p de cuerpoi ;
		cuerpoi->setPosicion( cuerpoi->getPosicion() + ( cuerpoi->getVelocidad() + v0 ) / 2 ) ;
		centrodemasa_.setPosicion( cuerpoi->getPosicion() ) ;
	centrodemasa_.setPosicion( centrodemasa_.getPosicion() / cuerpos_ ) ;
I use a few classes I made myself, since the basis of the project is to get a bit of practice. In case they help, I have the definitions right here. I'd appreciate anyone who could offer some insight into why I'm having this problem, or how to fix it.
Code:
#ifndef _nCuerpo_h_
#define _nCuerpo_h_
#include "nVector.h"
class nCuerpo
	public :
		nCuerpo ( ) ;
		nCuerpo ( const long double & , const nVector<long double> & , const nVector<long double> & , const nVector<long double> & ) ;
		nCuerpo ( const nCuerpo & ) ;
		~nCuerpo ( ) ;
		const long double getMasa ( ) const ;
		const nVector<long double> getVelocidad ( ) const ;
		const nVector<long double> getPosicion ( ) const ;
		const nVector<long double> getAceleracion ( ) const ;
		void setMasa ( const long double & ) ;
		void setVelocidad ( const nVector<long double> & ) ;
		void setPosicion ( const nVector<long double> & ) ;
		void setAceleracion ( const nVector<long double> & ) ;
		const bool operator == ( const nCuerpo & ) const ;
		const bool operator != ( const nCuerpo & ) const ;
	protected :
	private :
		long double masa_ ;
		nVector<long double> velocidad_ ;
		nVector<long double> posicion_ ;
		nVector<long double> aceleracion_ ;
#endif // _nCuerpo_h_
Code:
#ifndef _nLista_h_
#define _nLista_h_
#include "nNodoLista.h"
template < typename T >
class nLista
	public :
		nLista ( ) ;
		nLista ( const nLista<T> & ) ;
		~nLista ( ) ;
		void addObjeto ( const T & ) ;
		void addObjetoEnd ( const T & ) ;
		void removeObjeto ( ) ;
		// void removeObjetoAtras ( ) ;
		const bool findObjeto ( const T & ) const ;
		// const bool removeObjeto ( const T & ) ;
		T * getObjeto ( const unsigned int = 1 ) const ;
		const unsigned int getCantidad ( ) const ;
	protected:
	private:
		nNodoLista<T> * primero_ ;
		unsigned int cantidad_ ;
		void deleteNodo ( nNodoLista<T> * ) ;
#endif // _nLista_h_
Code:
#ifndef _nNodoLista_h_
#define _nNodoLista_h_
class nNodoLista
	public :
		nNodoLista ( ) ;
		nNodoLista ( const T & ) ;
		nNodoLista ( const nNodoLista<T> & ) ;
		~nNodoLista ( ) ;
		T * getObjeto ( ) ;
		void setSiguiente ( nNodoLista<T> * ) ;
		nNodoLista<T> * getSiguiente ( ) ;
	protected :
	private :
		T dato_ ;
		nNodoLista<T> * siguiente_ ;
#endif // _nNodoLista_h_
Code:
#ifndef _nSistema_h_
#define _nSistema_h_
#include "nCuerpo.h"
#include "nLista.h"
class nSistema
	public :
		nSistema ( ) ;
		nSistema ( const nSistema & ) ;
		~nSistema ( ) ;
		void addCuerpo ( const nCuerpo & ) ;
		void updateSistema1 ( ) ;
		//unsigned int cuerpos ( ) { return cuerpos_ ; } ;
		void drawSistema1 ( ) const ;
	protected :
	private :
		nLista<nCuerpo> sistema_ ;
		nCuerpo centrodemasa_ ;
		unsigned int cuerpos_ ;
#endif // _nSistema_h_
Code:
#ifndef _nVector_h_
#define _nVector_h_
class nVector
	public :
		const static int NVECTORSIZE = 3 ;
		nVector ( ) ;
		nVector ( const T & , const T & , const T & ) ;
		nVector ( const nVector<T> & ) ;
		~nVector ( ) ;
		nVector<T> & operator = ( const nVector<T> & ) ;
		nVector<T> & operator += ( const nVector<T> & ) ;
		nVector<T> & operator -= ( const nVector<T> & ) ;
		nVector<T> & operator *= ( const T & ) ;
		nVector<T> & operator /= ( const T & ) ;
		const nVector<T> operator + ( const nVector<T> & ) const ;
		const nVector<T> operator - ( const nVector<T> & ) const ;
		const nVector<T> operator * ( const T & ) const ;
		const nVector<T> operator / ( const T & ) const ;
		const T operator * ( const nVector<T> & ) const ;
		const nVector<T> Xprod ( const nVector<T> & ) const ;
		const bool operator != ( const nVector<T> & ) const ;
		const bool operator == ( const nVector<T> & ) const ;
		const T getNorma2 ( ) const ;
		const T getX ( ) const ;
		const T getY ( ) const ;
		const T getZ ( ) const ;
	protected :
	private :
		T data_ [ NVECTORSIZE ] ;
#endif // _nVector_h_
Technology news on Phys.org
The key here is the numerical integration used to calculate velocities and positions, which in turn are used to calculate acclerations for each time step. An iterative corrector method will improve the results. In the algorithm shown below, an, vn, and pn, are successive "guesses" that should converge quickly. F(...) calculates the acceleration based on pn(t), and Δt is the elapsed time per step. You may want to do 6 to 8 interations instead of the 4 shown in this example. The first step is essentially Euler (since a1(t) is set = F(p0(t)) (= a(t-1)), the remaining steps are trapezoidal. Even though each step of this algorithm will converge to a specific set of values, the algorithm is based on trapezoidal rule, a linear approximation, so you need to use small time steps (Δt).
v0(t) = v(t-1)
p0(t) = p(t-1)
a1(t) = F(p0(t)) (= a(t-1))
v1(t) = v(t-1) + 1/2 (a(t-1) + a1(t)) Δt
p1(t) = p(t-1) + 1/2 (v(t-1) + v1(t)) Δt
a2 = F(p1(t))
v2(t) = v(t-1) + 1/2 (a(t-1) + a2(t)) Δt
p2(t) = p(t-1) + 1/2 (v(t-1) + v2(t)) Δt
a3 = F(p2(t))
v3(t) = v(t-1) + 1/2 (a(t-1) + a3(t)) Δt
p3(t) = p(t-1) + 1/2 (v(t-1) + v3(t)) Δt
a4 = F(p3(t))
v4(t) = v(t-1) + 1/2 (a(t-1) + a4(t)) Δt
p4(t) = p(t-1) + 1/2 (v(t-1) + v4(t)) Δt
v(t) = vn(t)
p(t) = pn(t)
a(t) = F(pn(t))
time += Δt
t += 1
This is a predictor-corrector type algorithm:
http://en.wikipedia.org/wiki/Predictor-corrector_method#Euler_trapezoidal_example
Thanks! I'll give that a try, see how the program reacts and how many steps I'd need. I'd tried to figure decent ways to correct the error, such as trying to calculate the particle's energy at a given point and cut speed accordingly to keep energy constant, but hadn't gotten to figuring out how that would work.
http://en.wikipedia.org/wiki/Gravity_assist"
Right. Energy of the system doesn't change, not energy of each individual particle. As I said, was just an idea, didn't think it through.
If you use the integration method I described in my previous post and keep the time step (Δt) small enough, you shouldn't have an issue with errors with a reasonable number of orbital cycles (100 to 1000). As mentioned you could calculate the total energy of the system every 10 to 100 cycles, and if it's increasing or decreasing, apply a small correction factor to the process.
  • · Replies 36 ·
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 35 ·
  • · Replies 89 ·
