Calc. the deformation of a cable on a reel
  • Thread starter Thread starter ihaland
    Cable Deformation
The discussion revolves around the effects of placing a steel cable on a reel with an outer diameter of 3.51 m, focusing on the material properties of the cable, particularly in relation to its deformation and potential memory effects when unreeled. Participants explore various factors that may influence the cable's performance and structural integrity.
  • One participant inquires about the effects on material properties when a steel cable is placed on a reel, seeking guidance on how to approach the analysis.
  • Another participant questions whether the original poster is referring to memory effects in the cable when it is unreeled, emphasizing the need for specific details about the cable's properties, such as diameter and material composition.
  • A different participant notes that utilities commonly use steel or aluminum cables on reels of various sizes without apparent effects on material properties.
  • One participant elaborates on the tensile yield strength as a critical material property, suggesting that the minimum recommended radius of curvature for a 6 x 7 stranded cable should not exceed 48 mm for the given spool diameter, while also indicating that the number of strands affects this consideration.
  • There is a distinction made regarding the implications for stranded versus solid cables, indicating that further information about the cable's construction is necessary for a complete analysis.
Participants express differing views on the potential effects of the reel on the cable's material properties, with some asserting that there are no significant effects while others raise concerns about specific conditions related to the cable's construction.
The discussion highlights the importance of knowing the specific properties of the cable, including its construction and material characteristics, which are not fully detailed in the initial inquiry.
This discussion may be of interest to engineers, materials scientists, and professionals involved in cable manufacturing or utility operations, particularly those concerned with the mechanical properties of cables under different conditions.
ihaland
I want to see what effects placing a steel cable on a reel of size of OD 3,51 m will have on the properties of the material?
How will I go about doing this?
A appreciate any help I can get :-)
Not sure what effect you are thinking of. Do you mean memory in the cable? So when it is unreeled what might be expected? S
You need to know the properties of the cable, diameter, number of stands, material.
Utilities use steel or aluminum cable wound on 1 to 3 m reels all the time. I'm not aware of any affects on the material properties.
Well said by PhanthomJay. The material property of interest would be tensile yield strength. ihaland, for your given spool diameter, if we assume this is a 6 x 7 stranded cable (a somewhat coarse construction), then the nominal diameter of your cable could go up to 48 mm before you violate the minimum recommended radius of curvature. And the cable diameter could go even higher if your cable has more strands. Therefore, as PhanthomJay mentioned, you will be OK if your cable is stranded; no problem at all. If your cable is solid, the answer is different. Therefore, we would need to know how many strands are in your cable, and the tensile yield strength of your filament material.
  • · Replies 18 ·
