Register to reply
S3 question
by tyrannosaurus
Tags: None
Share this thread:
tyrannosaurus
#1
May23-10, 05:33 PM
P: 37
Let G=<a, b|a^2=b^2=e, aba=bab>. SHow G is isomorphic to S3.
2. Relevant equations
[b]3. The attempt at a solution[/
since a^2=b^2=e, then |a|=1 or 2 and |b|= 1 or 2. But since aba=bab, the orders of a and b both have to be 2 because if either had order 1, we would get that a=a^2 or that b=b^2. Since aba= bab, by left hand multiplication and right hand multiplication by ab and (ab)^-1 we get that (ab)(aba)(ab)^-1 = abab(ab)^-1= ab. So then ab and aba are conjugates, from this we can partion G by <aba>. So G= a<aba> union b<aba> union e<aba>. Thus G has at most 6 elements (since |aba|=2). SO |G|<= 6. From this, since |S|>=|G| we can show that S3 satisfies the defining relations of G.
Is my thinking on this right?
Phys.Org News Partner Science news on Phys.org
Mysterious source of ozone-depleting chemical baffles NASA
Water leads to chemical that gunks up biofuels production
How lizards regenerate their tails: Researchers discover genetic 'recipe'
Office_Shredder
#2
May24-10, 12:41 PM
Emeritus
Sci Advisor
PF Gold
P: 4,500
Quote Quote by tyrannosaurus View Post
If both a and b are the identity that's not a problem. Identifying rigorously groups represented in this form is kind of tricky, because it's not immediately obvious that everything isn't the identity. The definition is usually something like 'the largest group satisfying these properties' or maybe something involving a lifting property. You should check exactly what your definition is so you can use the definition in your proof
This is on the right track. A cleaner proof might start by identifying what a and b are supposed to be in S3 then defining a homomorphism from G to S3 that takes a and b to their respective elements. A couple of things that you should note that hold true in general (and you should think about if it's not obvious why it's true)
0) The homomorphism must be well defined. In this case it suffices to show that the images of a and b satisfy the properties that a and b satisfy in G
1) If G is in fact S3, the elements that a and b are sent to in S3 have to generate S3. Once you prove this you have that your homomorphism is onto.
2) Once 1 is done, all you have to do is check what the kernel is. An argument involving the sizes of the groups can work here (If the map is onto and G has only 6 elements, it has to be injective also)
tyrannosaurus
#3
May24-10, 01:37 PM
P: 37
thanks for your help, that helped a lot.
Register to reply
Related Discussions
Centrifugal and centripetal force question: race-car and banked curve question Introductory Physics Homework 12
Gravity/Planetary Forces Question - High School physics question Introductory Physics Homework 5
Insanely easy question - trig functions, need a quick question answered Precalculus Mathematics Homework 1
Rotation Question. Is there sufficient data/values? Pondered on question 4 sumtime.. Introductory Physics Homework 17
