Generating 40KHz Signal Bursts with 555 Timers
  • Thread starter Thread starter cat1cat
    Signal
The discussion focuses on generating 40 kHz signal bursts using two 555 timers, where one is configured as an astable circuit and the other as a monostable circuit. It is established that the proposed method will not work due to the continuous triggering of the monostable circuit. Instead, using a counter like the CD4020, CD4040, or CD4060 to gate the 40 kHz pulses is recommended for creating bursts. Additionally, utilizing a crystal oscillator for improved stability and considering the HEF4521 for longer burst durations are suggested solutions.
  • Understanding of 555 timer configurations (astable and monostable)
  • Familiarity with digital counters (CD4020, CD4040, CD4060)
  • Knowledge of oscillator circuits and crystal stability
  • Basic electronics principles related to signal gating
  • Research the operation and applications of the CD4020, CD4040, and CD4060 counters
  • Learn about crystal oscillators and their advantages over astable circuits
  • Explore the HEF4521 counter for generating longer signal bursts
  • Investigate signal gating techniques for generating precise bursts of frequency
Electronics engineers, hobbyists working on signal generation projects, and anyone interested in timing circuits and frequency modulation techniques.
cat1cat
hi. I have a project in hand. I have to make a 40 Khz continious wave into a burst of signals.
for this i am using 2 555 timers . 1st astable circuit and the output goes to the triger of the monostable circuit and then the output of this circuit is ANDed with the 40Khz continious waves from other circuit. Will this whole set it give burst of signal? please help...
No, that will not work.
The monostable will trigger again when it finishes the time-out because it is getting a continuous stream of pulses.
You could drive a counter with the 40 KHz pulses and then use the output of this to gate the 40 KHz pulses.
You can get crystals for 40 KHz and these would give much better stability than an astable.
If you wanted to consider the counter idea, have a look at the data sheets for the CD4020 CD4040 and CD4060 or the 74HC4020 etc.
You can string these together to get division by powers of 2.
Divisions like 8192, 16384 are available so you could get square wave outputs of 4.88 Hz and 2.44 Hz, so you could get bursts of 40 KHz for 0.1024 seconds or 0.2048 seconds
Another chip worth knowing about is the HEF4521 which will divide by up to 16777216 which would give a period of 419 seconds from your oscillator but you can get shorter times than this. Outputs of 2^18 to 2^24 are available. 40000 divided by 2^18 is 6.55 seconds, so you could get bursts of 3.28 seconds.
Have a look at this page for other counters:
http://www.xs4all.nl/~ganswijk/chipdir/f/counter.htm
Do you need just a single burst of 40 kHz or a repetitive burst?
For a single burst or a triggered burst, why not connect the output of the monostable to the reset input of the astable. For regular repetitions of the 40 kHz burst, just make the first 555 astable instead of monostable.
  • · Replies 58 ·
12K
  • · Replies 47 ·
  • · Replies 19 ·
