| Thread Closed |
can quantum length be derived not using gravity constant? |
Share Thread |
| Aug25-04, 09:56 AM | #1 |
The quantum of length is the Planck length given by
[tex] \lambda_p = \sqrt{\frac{Gh}{c^3}} [/tex] where G is the gravity constant. h is Planck's constant. c is the speed of light in vacuum. There might be unknown fundamental energy and force whose ratio can also give the quantum length. [tex] \lambda_p = \frac{E_0}{F_0} [/tex] |
| Aug25-04, 11:47 AM | #2 |
| Aug25-04, 12:08 PM | #3 |
You can get Planck mass (thus Planck length) as a combination of the fine structure constant, the electron mass, and the sine squared of Weinberg angle (at his unification value, 3/8). Nottale did it.
| Aug25-04, 01:30 PM | #4 |
selfAdjoint,
Is there such a thing as quantum of length even in LQG spacetime? |
| Aug25-04, 01:31 PM | #5 |
Thanks arivero. I will look up Nottale.
| Aug25-04, 01:42 PM | #6 |
selfAdjoint,
I'm starting reading Kaku's QFT, chap 19 on quantum gravity. Maybe I can find something from what you mentioned about LQG. |
| Aug25-04, 05:20 PM | #7 |
| Aug26-04, 06:54 AM | #8 |
Thank you, selfAdjoint. But what's the compelling technical reasons why volume can't be quantized? Common sense is telling me that volume should be the obvious 1st candidate for such quantization.
| Aug30-04, 04:00 AM | #9 |
Perhaps DSR, double special relativity, should be mentioned here. It uses a kinematical Planck length, with is assumed to be some multiple of the gravitational one, but it does not need to be.
Also, Marcus recently mentioned a acceleration got from cosmological parameters, which also can be transformed in a fundamental length. |
| Aug31-04, 10:23 AM | #10 |
Is it not that the combined effect of Planck parameters (length, mass, energy, time) is the domain where all the fundamental forces (EM, weak, strong, gravity) are unified? |
| Thread Closed |
Similar discussions for: can quantum length be derived not using gravity constant?
| Hubble's constant/length? | Cosmology | 2 | ||
| Planck mass; time; length derived out of air? | Quantum Physics | 5 | ||
| constant length bezier curve | General Math | 12 | ||
| Quantum Gravity with a Positive Cosmological Constant | Beyond the Standard Model | 0 | ||
| Loop quantum gravity and the cosmological constant problem | General Physics | 6 | ||
