Thread Closed
Small Reynolds Number Flow around Flat Plate
Share Thread
May27-10, 10:34 AM   #1
uby
Hello,
I have a problem I am trying to model analytically (please note: I am NOT a fluid mechanics expert -- I come from a chemistry background):
A semi-infinite plate is oriented axially in the direction of flow.
Please refer to the following page for an illustration of my problem:
http://www.ecourses.ou.edu/cgi-bin/e....3&page=theory
The third picture is the Blasius solution, which does not apply at small Reynolds numbers. I am looking for an expression to tell me the thickness of the shaded viscous region from the top two pictures (i.e. - for small Reynolds numbers!) as function of position from the leading edge.
Any references would be appreciated.
Thanks!!
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
May27-10, 05:08 PM   #2
What is the fluid, it's velocity and the size of the plate?
May27-10, 05:17 PM   #3
uby
hi RTW:
the fluid is argon at 1100 degrees celsius (kinematic viscosity 1.6 cm^2/sec) , traveling at 10 cm/s over a square rod (0.635x0.635cm, ~10cm length)
based on these values, i expect the reynolds number to vary from < 1 near the leading edge to ~60 far from the leading edge.
the blasius solution is only valid for reynolds numbers greater than about 1000, so i feel safe in assuming that it doesn't apply.
Thread Closed
Similar discussions for: Small Reynolds Number Flow around Flat Plate
Thread Forum Replies
Effect of reynolds number on flow in wave tank General Physics 0
Fluid Mechanics - Estimating Reynolds number and flow rate. Engineering, Comp Sci, & Technology Homework 1
Reynolds number Introductory Physics Homework 3
change in flow / velocity direction and the Reynolds number General Physics 0
Reynolds number may have a similar effect to the Knudsen number Mechanical Engineering 0
