Thread Closed
Force Couples - Computation of Forces
Share Thread
May30-10, 01:59 AM   #1
Hey folks, I'm rather stuck. I have a complete mental blank on this question. Having the force couple first has confused me I think
Compute the forece supported by the pin at C for the frame subjected to the 400-N.m couple
2. Relevant equations
3. The attempt at a solution
No idea where to begin!
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
May30-10, 05:14 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi SandboxSgt! Welcome to PF!
I'm not sure I understand what's happening at A and E.
Is E not resting on anything, but supporting an unknown weight?
And is A rotating frictionlessly about an axle resting on a fixed surface?
If so, start by taking moments about a convenient point, to find the weight (in newtons) supported at E.
May30-10, 05:31 AM   #3
Recognitions:
Start by calculating the force reactions at A and E using the basic equilibrium equations. Then use free body diagrams of each member and show your attempt at a solution.
May30-10, 06:54 AM   #4
Quote by tiny-tim View Post
G'day tiny-tim,
A acts as a roller, so has only a vertical reactive force, E is a pin therefore both a vertical and horizonal force...
Quote by PhanthomJay View Post
PhanthonJay, im just not sure how to start that, if I have a Force Couple of 400N.m shown where it is, how do I translate that into something I can start to find the reactions at A and E.
May30-10, 12:05 PM   #5
Recognitions:
Quote by SandboxSgt View Post
ok, then do A first instead of E …
start by taking moments about a convenient point, to find the reaction at A
what do you get?
May30-10, 05:47 PM   #6
Morning Tim!
This is where I get confused, in a force couple isn't it a moment itself? So for A i get Sum M(a) = (400) + B(4) therefore A = 100N ?
May30-10, 05:57 PM   #7
Recognitions:
Morning Tim!
Hi SandboxSgt!
I'm about to go to bed!
That's correct … whichever point you take moments about, a couple always goes in as a pure moment, of the same amount.
I'm confused … what's B, and which point are you taking moments about?
May30-10, 06:06 PM   #8
ERrr E not B! #$#@ I'm so over this question, I saw it in my sleep last night!
And I realise I've gotten that wrong...
M(a) = (400) + E(4) therefore E = 100N
M(e) = (400 x 3) +A(4) therefore A = 300N
May30-10, 06:15 PM   #9
Recognitions:
eek! you keep changing it!
No, one of E(4) and A(4) is wrong … moment isn't distance times force, it's distance cross force.
And where did 400 x 3 come from?
Goodnight!
May30-10, 06:24 PM   #10
Haha Night Mate...
Thanks for your help.
May30-10, 06:26 PM   #11
God damnit, its a 100N each!
If I could show you the reams of paper I have here, it was the first answer I worked out, but thought.... That can't be right!
tiny-tim, thanks for kicking my head into the right direction.
May30-10, 10:26 PM   #12
Recognitions:
Now that you have E and A, you must indicate their direction. Now continue to find the forces supported by the pin at C.
May31-10, 04:32 AM   #13
Well after many reams of paper, I have the reactions but am no where near the Forces in C. I know the answer is 224N, but I seem to just push around the moment. Either I'm missing something obvious or I'm just really not getting it.
If I have the reactions of A being 100N Up and E being 100N down, whats the next step?
What I do is take 100/Cos 45 which is equal to 141.421, move up to C, time 141.421 x 2 as there are two arms, then multiply by sin45 and I get 200 again... I know it's wrong....
Or I take moments, and get 400 at a point 2m below C..... #@$@#$@#$%^!
May31-10, 05:08 AM   #14
Recognitions:
Morning SandboxSgt!
You need to use moments for each rod separately
Let the reaction force on rod CDE (from rod ABC) be x right and y up …
what do you get?
May31-10, 05:37 AM   #15
I'm not sure I understand...
My reactions are at point A and E, if I take moments about B for ABC I get C = 0N
If I take moments about D I get C = 0N
I'm missing this bit in the thought process. I believe there are no horizontal forces on any of the points as there is no externally applied horizontal force?
May31-10, 07:38 AM   #16
Recognitions:
Hi SandboxSgt!
I assure you that I've done the problem myself (and got the correct answer, 224N), and there is a horizontal component.
Remember, if the reaction force on rod CDE (from rod ABC) is x right and y up, then the reaction force on rod ABC (from rod DEF) is x left and y down …
the internal forces always add to zero.
May31-10, 07:55 AM   #17
Thats the issue, I'm not sure how to get the reaction of one rod on the other...
Once I've worked out the reactions at A and E, does that mean the 400 is no longer touched or... I don't know...have spent close to 10 hours on this *cries* ;)
Thread Closed
Similar discussions for: Force Couples - Computation of Forces
Thread Forum Replies
Force couples - Finding resultant couple Engineering, Comp Sci, & Technology Homework 3
Moments and force couples...confused!! Introductory Physics Homework 1
Mechanics (Statics) - Forces/Couples exerted by flexible bearings? Engineering, Comp Sci, & Technology Homework 3
couples Advanced Physics Homework 10
Force couples Introductory Physics Homework 10
