Resonant frequency vs Natural frequency
The discussion centers on the distinction between resonant frequency and natural frequency, particularly in the context of beam resonance and its application to electrical circuits. Participants explore whether these terms are interchangeable or if they represent different concepts, especially considering factors like damping.
  • One participant expresses confusion about the difference between resonant frequency and natural frequency, suggesting they may be the same.
  • Another participant supports the idea that resonant frequency and natural frequency can be considered the same, particularly in mechanical systems where resonance occurs at natural frequencies.
  • A detailed explanation is provided regarding resonance, noting that mechanical systems can resonate at multiple natural frequencies, with the lowest being the fundamental frequency.
  • It is mentioned that in electrical circuits, the resonant frequency can be calculated using the formula f = (1/2π)√(LC), which may also be referred to as the natural frequency.
  • A later post introduces the concept of damped versus undamped natural frequency, indicating that they can differ, especially as damping increases.
  • Mathematical expressions are provided to illustrate the relationship between natural frequency and damped frequency in a parallel LRC circuit.
Participants do not reach a consensus on whether resonant frequency and natural frequency are the same. Some argue they are interchangeable, while others highlight the distinction, particularly in the context of damping effects.
The discussion includes references to specific mathematical formulations and conditions under which the terms may differ, such as the presence of damping in oscillatory systems.
sgsawant
I happened to sit in a presentation where the presenter displayed 2 separate values for resonant frequency and natural frequency. It was my understanding that the both are same and now I am in doubt.
Please explain - if there is and you know - the difference between resonant frequency and natural frequency.
I am specifically referring to beam resonance (and by extension - through its lumped element model - resonance in electrical circuits).
Regards,
-sgsawant
Here's a +1 for them being the same, as far as I know.
Resonance is a condition in which a vibrating system responds with maximum amplitude to a periodic driving force.
Mechanical systems (beams, pendula, springs, wine glasses, guitar strings etc) will have a number of possible frequencies at which this occurs. These are the system's natural frequencies of vibration. For example, a guitar string will have a series of possible frequencies where this happens, the lowest is called the fundamental frequency. The other frequencies are at values which are whole number multiples of the fundamental.
When resonance occurs, the frequency is often called a resonant frequency. This is just saying that resonance occurs when the driving force has the same value as one of the natural frequencies.
A beam can have more than one natural frequency, and therefore can be made to resonate at more than one frequency.
An (LC) series electrical circuit will resonate at a frequency given by f= (1/2π)√LC
This could be called its natural frequency or its resonant frequency. It doesn't really matter. (It's usually called its resonant frequency.)
Thanks a lot! o:)
Regards,
-sgsawant
The presenter was most likely referring to the damped natural frequency versus the undamped natural frequency. When the damping factor is small the two are very similar, but as the damping is increased the oscillation frequency decreases.
For example in a parallel LRC circuit the undamped natural frequency is :
[tex]\frac{1}{\sqrt{LC}}[/tex]
whereas the actual oscillation frequency of the natural response's damped sinusoid is :
[tex]\sqrt{\frac1{LC} - \frac{1}{(2RC)^2}}[/tex]
@uart
Well that's exactly what I was looking for. Thanks! Can you point me to your source or give me a link that explains the concept?
Regards,
-sgsawant
The characteristic equation for a second order system is of the form :
[tex]s^2 + 2 \alpha s + w_0^2[/tex]
For example in a parallel LRC circuit this would correspond to a function of the form :
[tex]s^2 + \frac{1}{RC} s + \frac{1}{LC}[/tex]
If the damping factor (alpha) is zero then the roots are at
[tex]\pm j \sqrt{1/(LC)}[/tex]
and it follows that the natural response is an undamped sinusoid of frequency 1/sqrt(LC).
When alpha is non zero the roots of the (quadratic) characteristic equation are
[tex]-\alpha \pm j \sqrt{(w_0^2 - \alpha^2)}[/tex]
from which it follows that the natural response is a damped sinusoid of frequency [itex]\sqrt{(w_0^2 - \alpha^2)}[/itex].
Great!
13K
  • · Replies 52 ·
18K
