| Thread Closed |
Astronaut weight |
Share Thread |
| Jun2-10, 09:08 AM | #1 |
Astronaut weight
An astronaut weighs 1000N at the surface of the earth of radius 6500 km, what his weight will be at 13000 km and 19500km from the centre of the earth?
Do I have to calculate the new value of g at 13000 km using the following? (G• Mearth) / (Rearth)2 Where: G = 6.673 x 10-11 N m2/kg2 Mass of the earth = (5.98 x 1024 kg) New Re = 13000 km (converted to m) Then W = M x g Is there another way of solving it? |
| Jun2-10, 01:24 PM | #2 |
You can calculate the answer without knowing the values G and M (or GM). Try write up the equation for the weight W1 at radius R1 and the weight W2 at radius R2 using GM as you did above and then look at the ratio W1/W2.
| Jun4-10, 04:11 AM | #3 |
Great answer Filip, thanks
| Thread Closed |
Similar discussions for: Astronaut weight
| error: your goal weight is greater than your starting weight | General Discussion | 18 | ||
| astronaut | Introductory Physics Homework | 4 | ||
| the apparent weight of an astronaut in space if... | Introductory Physics Homework | 9 | ||
| why does astronaut feel ' no weight ' when in space? | General Physics | 10 | ||
