What is the Pressure on the Circular Side of a Cylindrical Drum of Molasses?
  • Thread starter Thread starter fergust
    Cylindrical Drum
The discussion focuses on calculating the pressure exerted on the circular side of a cylindrical drum of molasses that is 25% full. The drum has a height of 4 ft and a radius of 1.5 ft, with a weight density of molasses at 100 lb/ft³. The pressure is determined using the formula: pressure = weight density x depth. The challenge lies in accurately determining the depth of the molasses to compute the pressure, as it varies across the circular side of the drum.
  • Understanding of fluid mechanics principles
  • Knowledge of pressure calculations in physics
  • Familiarity with integration techniques
  • Basic geometry of cylindrical shapes
  • Study the concept of hydrostatic pressure in fluids
  • Learn about integrating pressure over surfaces in fluid mechanics
  • Explore the properties of fluids, specifically weight density
  • Review calculations involving cylindrical volumes and cross-sections
Students in physics or engineering courses, particularly those studying fluid mechanics, as well as educators looking for practical examples of pressure calculations in cylindrical containers.
fergust
A cylindrical drum of molasses is 25% full and laying on its side. The dimension sof the drum are 4 ft. height and 1.5 ft. radius. Find the pressure on the circular side (end) of the drum) created by the molasses.
Weight density of molasses = 100 lb/ft^3
Total volume of drum = 9pi ft^3
Volume of molasses = 2.25pi ft^3
Thank you!
That's it?
We can't help you unless you make an effort to solve the problem first.
I wonder if the makers of this problem really want the pressure, or if they want the maximum pressure, or the force on the lid of the drum. The pressure is not constant.
To find the pressure you have to calculate weight density x depth. Finding the depth
will be the tricky part.
If you want to calculate the force, you have to integrate the pressure over the part of the side that's covered in molasses.
  • · Replies 18 ·
