| Thread Closed |
Resultant time dilation from both gravity and motion |
Share Thread | Thread Tools |
| Jun5-10, 12:44 AM | #86 |
Resultant time dilation from both gravity and motionNone of these are captured by the solution that uses the truncated metric. Why is this so difficult for you to understand? |
| Jun5-10, 12:47 AM | #87 |
The point is that kev used a truncated metric. Do you dispute that? Using a truncated metric, he got a particular solution, that isn't valid in the general case. Do you dispute that? I posted the general solutions for both orbital and radial motion using the full metric. Do you dispute that? Both solutions are correct. Do you dispute that? Heck, I even posted a superset of the solution , using the Kerr metric. Do you have any complains about it? |
| Jun5-10, 01:00 AM | #88 |
Recognitions:
| Jun5-10, 01:02 AM | #89 |
I understand very well, please stop talking down to me. I asked you a set of questions, would you please answer them as a set (all of them in one post)? Thank you |
| Jun5-10, 01:04 AM | #90 |
Recognitions:
| Jun5-10, 01:10 AM | #91 |
Could you please answer all my questions, in one post and without turning every point into your question? |
| Jun5-10, 01:18 AM | #92 |
Recognitions:
| Jun5-10, 01:26 AM | #93 |
Recognitions:
Going to bed now, will continue tomorrow... |
| Jun5-10, 01:26 AM | #94 |
(Basically you are trying to convey the idea that a half circle is a full circle. ) |
| Jun5-10, 01:59 AM | #95 |
| Jun5-10, 05:28 AM | #96 |
It's as if you are just looking at the maths, but completely ignoring the physics. |
| Jun5-10, 05:35 AM | #97 |
You are right to question this and I apologise for any confusion caused. When trying to answer your question I realised that basically I got this bit completely wrong. This is how it should be done: The proper time of a moving clock at r relative to the reference clock at infinity in Schwarzschild coordinates is (using your notation): [tex] \text{d}\tau = \text{d}t \sqrt{1-r_s/r} \sqrt{1- (1-r_s/r)^{-2}(\text{d}r/c\text{d}t)^2 - (1-r_s/r)^{-1}(r \text{d}\Omega/c\text{d}t)^2 }[/tex] The proper time of an observers clock [itex]d\tau_0[/itex] relative to the reference clock at infinity with motion [itex]dr_o/dt_o[/itex] and [itex]d\Omega_o/dt_o[/itex] at radius [itex]r_o[/itex], is given by: [tex] \text{d}\tau_o = \text{d}t \sqrt{1-r_s/r_o} \sqrt{1- (1-r_s/r_o)^{-2}(\text{d}r_o/c\text{d}t_0)^2 - (1-r_s/r_o)^{-1}(r_o \text{d}\Omega_o/c\text{d}t_o)^2 }[/tex] The ratio of the proper time of the two clocks is then: [tex] \frac{\text{d}\tau}{\text{d}\tau_o} = \frac{\sqrt{1-r_s/r\;}}{\sqrt{1-r_s/r_o}} \frac{\sqrt{1- (1-r_s/r\;)^{-2}(\text{d}r\;/c\text{d}t\;)^2 - (1-r_s/r\;)^{-1}(r\: \text{d}\Omega\;/c\text{d}t\;)^2 }}{ \sqrt{1- (1-r_s/r_o)^{-2}(\text{d}r_o/c\text{d}t_0)^2 - (1-r_s/r_o)^{-1}(r_o \text{d}\Omega_o/c\text{d}t_o)^2 }}[/tex] This is the completely general case of the ratio of two moving clocks in the Schwarzschild metric. If the observer is stationary at [itex]r_o[/itex] the equation reduces to: [tex] \frac{\text{d}\tau}{\text{d}\tau_o}= \sqrt{\frac{1-r_s/r}{1-r_s/r_o}} \sqrt{1- \frac{(\text{d}r/\text{d}t)^2}{c^2(1-r_s/r)^2} - \frac{(r \text{d}\Omega/\text{d}t)^2}{c^2(1-r_s/r)} }[/tex] <EDIT> THe above has been edited to correct a typo. |
| Jun5-10, 05:56 AM | #98 |
| Jun5-10, 06:12 AM | #99 |
Thanks kev. So
[tex]\frac{\text{d}\tau}{\text{d}\tau_o}[/tex] here is the ratio of the observer's clock and the observed clock(for lack of a better term) as seen by a second observer at infinity, correct? It is probably just my intuitive understanding that is failing me, but is this ratio the same ratio as observed by the first observer at [tex]r_0[/tex]? I think an SR example can explain my confusion: Define the frame S, in which there is an observer at rest. In S, there are frames S' and S'' with observers at rest going at speeds [tex]v_1=\beta_1 c[/tex] and [tex]v_2=\beta_2 c[/tex] respectively in S. Now the rest observer can measure [tex]t=\gamma_1\tau_1=\gamma_2\tau_2[/tex] The rest observer in S measures the ratio of the proper times of the rest observers in S' and S'' to be [tex]\frac{\text{d}\tau_1}{\text{d}\tau_2}=\frac{\gamma_2}{\gamma_1}=\sqrt{\ frac{1-\beta_1^2}{1-\beta_2^2}}[/tex] In S', the observer in S'' is travelling at the speed [tex]v_2^{\prime}=\frac{\beta_2-\beta_1}{1-\beta_1\beta_2}c[/tex] and since [tex]\tau_1=\gamma_2^{\prime}\tau_2[/tex] the observer in S' measures [tex]\left(\frac{\text{d}\tau_2}{\text{d}\tau_1}\right)^{\prime}=\sqrt{1-\left(\frac{\beta_2-\beta_1}{1-\beta_1\beta_2}\right)^2}=\frac{\sqrt{1+\beta_1^2\beta_2^2-\beta_2^2-\beta_1^2}}{1-\beta_1\beta_2}[/tex] Unless I made an error underway (which is very possible, this was a messy calculation), obervers S and S' dont seem to agree on the value of [tex]\frac{\text{d}\tau_2}{\text{d}\tau_1}[/tex]. |
| Jun5-10, 06:18 AM | #100 |
| Jun5-10, 06:26 AM | #101 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Resultant time dilation from both gravity and motion
| Time Dilation and Gravity | Special & General Relativity | 5 | ||
| Gravity time dilation in the Earth? | Special & General Relativity | 13 | ||
| Time dilation where there is no net gravity? | Special & General Relativity | 9 | ||
| Time Dilation+Gravity | Special & General Relativity | 10 | ||
| Gravity- time dilation | Special & General Relativity | 4 | ||
