How can I find the exact area under the graphs of these two functions as limits?
  • Context: Undergrad
  • Thread starter Thread starter Caldus
This discussion focuses on calculating the area under the graphs of two functions using limits and Riemann sums. For the function f(x) = ln(x)/x over the interval [3, 10], the area can be expressed as the limit of a Riemann sum: lim as n->infinity (7/n)[Sigma i = 0 to n](ln(3 + (7/n)i)/(7/n)). For the second problem, the area is determined by the limit of the Riemann sum: lim as n->infinity (Sigma i = 0 to n)(4pi/4n)(tan(i*pi/4n)), representing the area under the curve y = 4 tan(x) from x = 0 to x = pi/4.
  • Understanding of Riemann sums
  • Familiarity with limits in calculus
  • Knowledge of logarithmic and trigonometric functions
  • Ability to manipulate summation notation
  • Study the concept of Riemann sums in more detail
  • Learn about the Fundamental Theorem of Calculus
  • Explore the properties of logarithmic functions and their integrals
  • Investigate the behavior of trigonometric functions in calculus
Students and educators in calculus, mathematicians interested in integration techniques, and anyone looking to deepen their understanding of limits and areas under curves.
Caldus
Hey,
Having trouble with these two problems:
1. If f(x) = ln(x)/x (3 <= x <= 10), find an expression for the area under the graph of f as a limit. Do not evaluate the limit.
My answer:
Change in x = (10 - 3)/n = 7/n, so:
(7/n)[Sigma i = 0 to n](ln(7/n)/(7/n))
I feel like this isn't right for some reason.
2. Determine a region whose area is equal to:
lim as n->infinity of (Sigma i = 0 to n)(4pi/4n)(tan (i*pi/4n))
pi/4n is constant so that is the change in x.
Don't know how to go any further here...
And help appreciated.
1. One obvious point- the quantity inside the sum, ln(7/n)/(7/n) is a constant, it doesn't depend on i! Think carefully about what you are doing: You have divided the interval from 3 to 10 into n intervals, each of length 7/n. If x is the left hand endpoint, then the function value there is ln(x)/x so that is what you are using as the height of the rectangle. The area of each small rectangle is (7/n)(ln(x)/x) and x is NOT 7/n: that's the change from one x to another. In fact, x= 3+ (7/n)i ("3+ " because you are starting at 3, "(7/n)i" because you are move 7/n for each increase in i).
2. Take x=0 as the left endpoint to simplify the calculations. Since the only dependence on i is "i*pi/4n", it appears that you are using a step of pi/4n. That tells us two things:(a) the total change is from 0 to n(pi/4n)= pi/4 so the region must run from 0 to pi/4, (b) the base of each rectangle is pi/4n so the height mujst be the
4 tan(i*pi/4n) part and the function itself must be 4 tan(x).
The region you want is the region bounded on the top by y= 4 tan(x), on the bottom by y=0, on the left by x=0, and on the right by x= pi/4.
Hey there,
For the first problem, you are on the right track. The expression for the area under the graph of f can be represented as a Riemann sum, which is what you have written. However, you need to take the limit as n approaches infinity to get the exact value. So the final expression would be:
lim as n->infinity (7/n)[Sigma i = 0 to n](ln(7/n)/(7/n))
For the second problem, you are correct that pi/4n is the change in x. To determine the region, you need to take the limit as n approaches infinity of the Riemann sum, which represents the area under the curve. So the final expression would be:
lim as n->infinity (Sigma i = 0 to n)(4pi/4n)(tan (i*pi/4n))
I hope this helps! Let me know if you need any further clarification or assistance. Good luck!
  • · Replies 24 ·
