Is a Matrix with Two Distinct Eigenvalues Always Diagonalizable?
  • Thread starter Thread starter hitmeoff
    Matrix
The discussion revolves around the diagonalizability of a matrix with two distinct eigenvalues, specifically focusing on the implications of the dimensions of the corresponding eigenspaces.
  • Participants explore the relationship between the dimensions of the eigenspaces associated with the distinct eigenvalues and the conditions for diagonalizability. Questions are raised about the implications of having one eigenspace dimension equal to n-1 and the corresponding dimension of the other eigenspace.
Some participants suggest that if one eigenspace has dimension n-1, the other must be 1, leading to considerations about the direct sum of the eigenspaces. There is an ongoing exploration of how these dimensions relate to the overall structure of the vector space.
The discussion is framed within the context of linear algebra, particularly focusing on eigenvalues and eigenspaces, with an emphasis on the properties of diagonalizable operators in finite-dimensional spaces.
hitmeoff
Suppose the A [tex]\in[/tex] Mn X n(F) has two distinct eigenvalues, [tex]\lambda[/tex]1 and [tex]\lambda[/tex]2, and that dim(E[tex]\lambda[/tex]1) = n -1. Prove A is diagonalizable.
1. The charac poly clearly splits because we have eigenvalues.
2. need to show m = dim (E).
Ok, we are given that dim(E[tex]\lambda[/tex]1) = n - 1
we know multiplicity has to be 1 [tex]\leq[/tex] dim(E[tex]\lambda[/tex]1) [tex]\leq[/tex] m.
so: 1 [tex]\leq[/tex] n - 1 [tex]\leq[/tex] m.
But I am stuck now, not sure how to show that m = dim(E[tex]\lambda[/tex])
We're told that [tex]dimE^{\lambda_1}[/tex] is [tex]n-1[/tex]. What is [tex]dimE^{\lambda_2}[/tex] then, and what can you say about [tex]E^{\lambda_1} \oplus E^{\lambda_2}[/tex]?
[tex]dimE^{\lambda_2}[/tex] = 1 then right?
[tex]E^{\lambda_1} \oplus E^{\lambda_2}[/tex] = V?
A linear operator T on a finite-dimensional vector space V is diagonalizable iff V is the direct sum of eigenspaces of T.
