Challenging the Role of Photons in Explaining Light's Particle Behavior
  • Thread starter Faradave
  • Tags
    Photons
In summary, SR says photons don't age because they travel at c (the limit of time dilation). However, in frame c, a photon sees its path length as zero (the limit of length contraction), which equates to "contact." Equating "zero path length" to "contact" would seem sufficient to explain all of light's particle behavior (photoelectric effect, Compton effect, even virtual photon "exchanges") without invoking massless energy bundles, and photons are necessary for the modern Standard Model of particle physics.
  • #36
Faradave said:
I assert that a speed of light reference frame (Frame c) is a relativistic inertial reference frame because its motion is uniform and all photons have speed .
Ok,
Can you derive the transformations between your "Frame c" and the other inertial frames?
All the other inertial frames are connected by the Lorentz transforms, derive the transform that connects your "Frame c" with the rest.
  • #37
I use the limiting case where velocity of the frame approaches c. Time stops (goes to infinity), path length goes to zero and contact between emitting and absorbing particle occurs. I believe the particle aspects of light are not an accident or mysterious but a simple collision.
Controversy arises when people mistakenly presume a photon is “at rest” in Frame c. That is resolved two ways. First, a “photon’s” instantaneous velocity remains c as path length shrinks to zero. Zero path length is not itself problematic as there is no obligatory distance required for any photon in relativistic inertial reference frames (RIRFs). But with path length zero a photon is obviously superfluous. So second, photons were never more than a very useful accounting tool in any frame (in my view). I replace photons with pinholes (photo-induced wormholes).
There is room for debate about the meaning of “contact” as the position and velocity of electrons is uncertain and their diameters (let alone surfaces) are indeterminate for what are often referred to as “point particles”. But a functional definition is still available to us. For this discussion, “contact” is: sufficient proximity for transfer of kinetic energy (and momentum). In the test case illustrated in #34 asserting a remote collision between electron and positron (via light transmission) contact is: sufficient proximity to result in annihilation. I offer this as both necessary and sufficient to the confirmation of pinholes. Except for this discussion, such an occurrence is, to my knowledge, completely unanticipated. To the extent that contact may "work" at distances greater than zero (Planck length?), the discussion only shifts toward more established RIRFs and pinholes.
  • #38
So, where are your formulas for the transformation I asked you? Can you show them?
  • #39
l=ct, l'=c't', c=c' {...goose bumps}
  • #40
There are not transforms, these are nothing.
  • #41
Faradave -- There's a good reason why the concept of photon has survived for over a century -- the concept is immensely useful, spanning many branches of physics, and it passed many tests with flying colours. Simply stated, there is no reason to challenge the idea of a photon -- there's no evidence at all that the concept is wrong.
To gain any legitimacy, you must show 1. that your ideas agree with experiment, and 2. the specifics of where current theory is not correct and your theory is.
You have yet to do this.
Lot's of luck.
Regards,
Reilly Atkinson
  • #42
Light from the sun is slowed when entering water. What is its speed after emerging from the water?
  • #43
c.
BTW, light is not slowed down in water, its path is lengthened. This is a complex phaenomenon.
  • #44
We know that light is slowed when passing through water. Is this slowing cumulative? What is the speed of the same light upon emerging from the water?
  • #45
Btw: I disagree. But let me put it another way. When I see objects that are under water, like a tasty tuna, I know that this light has passed through a given distance, let's say 100 feet. 100 feet is the same distance whether in air or water. Is the light from the tuna faster after leaving the water?
  • #46
No.
I have already answered that, c.
  • #47
Fysiks Phan said:
Btw: I disagree.
That's your problem. Taking a physics class might help.
Actually light in the water has taken a complex, zig-zag path, not a straigh one like in vacuum.
No, see above.
No. It is still c.
  • #48
This shows that you have literally no idea what Relativity in its special or general formulation is. None at all, which is alright, but not if you're trying to debunk photons, instead of learning basic physics.
  • #49
starthaus said:
...these are nothing.
They were quite something to Dr. Einstein, especially the last one, c=c'.
  • #50
Faradave, what is being asked for here are equations that express l' and t' in terms of l and t (although I'd prefer to use the symbol x instead of l), not just for the motion of photons but for any arbitrary events.
Hint: the Lorentz transform between two inertial frames is conventionally given by the equations
[tex]t' = \gamma(t -vx/c^2)[/tex]
[tex]x' = \gamma(x - vt)[/tex]​
where [itex]\gamma = 1/\sqrt{(1-v^2/c^2)}[/itex].
  • #51
DrGreg said:
Faradave, what is being asked for here are equations that express l' and t' in terms of l and t...
DrGreg, Thankyou for your kind assitance to me and Starthaus. I couldn't help but think these were rather generally available in PF and elsewhere such as (http://en.wikipedia.org/wiki/Length_contraction). And a look at the Starthaus posts/blogs suggest that full use of these has already been made.
The more basic equations I offered, while not transforms in themselves, contain all the elements necessary to derive them (with a little help from Pythagoras). Alas, like my pseudonamesake, my math (and Latex) skills are not up to par and I am left at the mercy of intuition and the benevolence of aquaintences such as yourself.
Also like Faraday, I love to attend lectures, particularly those offered by The Teaching Company. One entitled, "Einstein's Relativity and the Quantum Revolution" by Dr. Richard Wolfson, offered a form which I like:
[tex]t'=t\sqrt{1-v^{2}}[/tex]
and the same for length, where v is the velocity of the moving frame expressed as a fraction of lightspeed.
  • #52
Faradave said:
I assert that a speed of light reference frame (Frame c) is a relativistic inertial reference frame because its motion is uniform and all photons have speed c (even those traveling zero distance).
Hi Faradave, I agree with starthaus, you need to do more than assert this, you need to derive this. You have been given good reasons by many people why your assertion is wrong, so you need to back up your assertion with some solid derivation.
What you are being asked for is for the complete set of 4 equations of the following form:
t'=f1(t,x,y,z)
x'=f2(t,x,y,z)
y'=f3(t,x,y,z)
z'=f4(t,x,y,z)
which will allow you to transform from a standard inertial frame coordinates (t,x,y,z), to your frame c coordinates (t',x',y',z'). This transformation needs to transform all coordinates (t,x,y,z) in the standard inertial frame, not just those on a light cone as in post 39 and not just those which are co-located as in post 51.
Once you have given this transformation rule then you can prove that your frame c is inertial by writing down the laws of physics in the unprimed frame, doing the transform, and demonstrating that they have the same form in the primed frame. Anything less is insufficient.
  • #53
Faradave,
the reason starthaus, DaleSpam & myself are asking you for these transforms is because we don't believe there is any sensible answer that will apply apply between your "frame c" and a standard inertial frame, which is why everyone has been objecting. So it's up to you to prove us wrong and come up with a sensible answer as DaleSpam spelled out in more detail.
  • #54
DrGreg said:
Faradave,
Actually, we know that there is no such thing.
  • #55
t'=f1(t,x,y,z)
x'=f2(t,x,y,z)
y'=f3(t,x,y,z)
z'=f4(t,x,y,z)
You also need to show that there is an inverse transformation that has the following form:
t=f5(t',x',y',z')
x=f6(t',x',y',z')
y=f7(t',x',y',z')
z=f8(t',x',y',z')
which "goes the other way", i.e. transforms from the (t',x',y',z') calculated with the preceding transformation back to the original (t,x,y,z), and only to the original (t,x,y,z).
  • #56
DrGreg said:
...we don't believe there is any sensible answer that will apply apply between your "frame c" and a standard inertial frame, which is why everyone has been objecting. So it's up to you to prove us wrong...
This is in response to the impressive consensus that I must provide a satisfactory set of transforms relating my Frame c (moving at lightspeed) to standard inertial reference frames. These began at post #36 with starthaus. I think it’s obvious that I will not be forthcoming with these any time soon. Perhaps it would be worth the effort, but some of you are quite certain the task would be futile.
I hope it is safe to assume, since you are active in the Relativity forums, that you all believe that the speed of light is absolute, that time “really” dilates, that length “really” contracts and that simultaneity is relative.
Any thinking time dilation to be an illusion should have been convinced by the change in time captured between a still and a previously synchronized Cs clock returning from a round trip to other frames. Being covariant with velocity, length contraction is equally real, but to date there has been no direct way to capture that. A game of tag (between electron and positron) could fix that, as long as length contraction is real, all the way down to zero.
Thus, my OP suggesting photons are, though useful, superfluous to a model of remote contact through pinholes (photo-induced wormholes) mediated by path contraction to zero. The pushback was loud and clear: Path contraction does not go to zero because Frame c is not a relativistic inertial reference frame (RIRF). Specifically, Frame c is disallowed because photons can never be “at rest”. I solved that. Frame c has uniform motion and all light travels at speed c, even when distance is zero.
Now, I am “burdened” with another task. Why? I am of the impression all Frames<c in uniform motion and with c=c’ are accepted as RIRFs. And a great accomplishment of SR is that it gives us that the laws of physics (including electricity and magnetism) are the same in all RIRFs.
But here’s the kicker. Suppose I take a year, become adept at these transforms, run into your "unsolvable" problem and in a flash of brilliance fix it? I then come back here and, by golly, you’re all impressed! Great, right? Then someone does the first spectral analysis of antihydrogen and there’s no spooky annihilation at a distance (illustration post #34). What's been accomplished? Nothing! No pinholes! I’m WRONG anyway!
Alternatively, I wait till that experiment is done. And son of a gun, they get all kinds of unexpected antihydrogen instability. A lot like Mills & Cassidy had with positronium (see post #16). Then someone finds matching gamma emissions from the antihydrogen and from its remote illumination source. Pretty soon, folks like you (who are far more capable anyway) are busy fixing the transforms lickety-split. That’s more likely the way it’s going to work out.
Meanwhile, l’=ct’ is about my speed. A nice linear equation with slope c in every frame, even the limit as l’ goes to zero. With or without transforms, pinholes offer simplification and potential answers to many of the outstanding problems in physics today.
  • #57
Alternatively, I wait till that experiment is done. And son of a gun, they get all kinds of unexpected antihydrogen instability. A lot like Mills & Cassidy had with positronium (see post #16). Then someone finds matching gamma emissions from the antihydrogen and from its remote illumination source. Pretty soon, folks like you (who are far more adept anyway) are busy fixing the transforms lickety-split. That’s more likely the way it’s going to work out.
This is simple, provide the derivations, and if you can't admit that and go away, the "golly" possibility is your own fantasy, not reality.
  • #58
Because this is how science is done, particularly revolutionary science. Take a look at Einstein for example, even he was not allowed to simply have a flash of physical insight and then leave the detailed work to others, he had to go through the derivations and the detailed math and lay it out for the scientific community to judge. Do you somehow think that you are more of a genius than Einstein? That you should be given a "pass" where he was not due to the sheer granduer of your ideas?
Again, that is science! I had a friend in grad school who spent not just one year but several years on his dissertation research and at the end his conclusion was that his initial idea was wrong. Negative results in science are important too.
You seem to think that you can change the world without effort and that your big picture is the only important thing and the details can be ignored. You seem to think that your idea is so compelling that you should not have to do any work and that the successful outcome of any attempt should be guaranteed. Sorry, that is simply not science, it is a lot of tedious work without any guarantee that nature will conform to your beautiful vision. If you can't be bothered to put in the scientific effort for your own idea then why should anyone else do it?
  • #59
That would be a better use of your time than spending time to post fringe stuff.
Not a chance.
You have been wrong all along.
So far, despite grandiose claims, you demonstrated that you don't know basic stuff.
  • #60
nismaratwork said:
Yeah, I meant to say that. So there!
After three times, you should realize, mere heckling doesn’t help. Your parroting is Bohr-ing, in view of the fact that Einstein would have gladly sacrificed his photons for quantum non-local connections (such as pinholes). It was clear from, “I think it’s obvious that I will not be forthcoming with these” that I am a Faradave, without a McSwell to help with the math (Any volunteers?) It did not stop Faraday from making his contributions.
If you want to help, give me a symptom. With Frame c a relativistic inertial reference frame (RIRF), what physical problem arises from your lack of satisfactory transforms? Or, you can just wait with me for the spectral analysis of antihydrogen. What I offer you is a chance to get a head start on fixing the transforms yourself.
Ha! That’s what they said about those nagging infinities in QED (such as charge on a proton) just before they came up with “renormalization”! Or you’ll invent a word like “duality” to sweep your problem under. But believe me, if spooky annihilation at a distance occurs, you will think of something, because observation must always trump theory.
  • #61
Without the transforms "frame c" is not even clearly defined, and the form of the laws of physics in it are completely unknown. No experimental predictions may be made and the results of experiments cannot be compared to their expected values.
  • #62
DaleSpam said:
Without the transforms "frame c" is not even clearly defined...
OK. But isn’t it true that you have no problem with Frame<c, even with v very close c, where path length may contract down to a Planck unit? For all we know, that is sufficiently close for “contact” - transfer of energy and momentum or even annihilation. So I've given you a, "renormalization solution". I've redefined "contact" so that it exists in a Frame<c that we can all live with.
I have no problem with that. I just feel that pinholes offer a much more tangible explanation for the particle aspects of light than “photons”. Everywhere you have a photon impact, I have a "real contact".
The difference is that pinholes predict annihilations with light between electron and positron and photons don’t. Pinholes also offer equally tangible explanations for many other phenomena where we only have descriptions now. And the wave aspects of pinholes are not mutually exclusive, the way duality is.
  • #63
Physics Forums Rules,
https://www.physicsforums.com/showthread.php?t=5374
in part, say
Overly Speculative Posts: One of the main goals of PF is to help students learn the current status of physics as practiced by the scientific community; accordingly, Physicsforums.com strives to maintain high standards of academic integrity. There are many open questions in physics, and we welcome discussion on those subjects provided the discussion remains intellectually sound. It is against our Posting Guidelines to discuss, in most of the PF forums or in blogs, new or non-mainstream theories or ideas that have not been published in professional peer-reviewed journals or are not part of current professional mainstream scientific discussion.
Personal theories are not allowed here.
