Angular Magnification
by A_lilah
Tags: angular, magnification
A_lilah
A_lilah is offline
#1
Jun7-10, 12:41 AM
P: 54
If you have normal vision and are properly using a magnifying glass with a refractive power of 12.5 diopters, how far should you hold it from the object to achieve maximum angular magnification?
2. Relevant equations
1 diopter = 1/focal length = m^-1
M=angular magnification
Mmax = [(Near Point)/f] +1
Near point for someone with normal vision = 25cm
3. The attempt at a solution
First I use 12.5 diopters to figure out the focal length:
1/12.5 = .08m = 8cm
Then I plugged this into the equation for Mmax for someone with normal vision:
[25cm / 8cm] + 1 = 4.125 = Mmax
I don't know how to use any of this to find the maximum distance the object should be held at though. The prof already posted the answers-this should be 6.67 cm- I'm just trying to practice before an exam and learn how to do this, so any help/tips would be great. Thanks!
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
Nax13
Nax13 is offline
#2
Jun9-10, 11:14 AM
P: 4
Maybe you can use this:
M = (f-v)/f
4.125 = 8-v/8
v = 25cm
I am not so sure abt the answer. Another formula that you might find useful is M = f/(f+u)
Register to reply
Related Discussions
Angular magnification Advanced Physics Homework 0
Angular Magnification Introductory Physics Homework 3
Angular Magnification of Microscope Introductory Physics Homework 1
angular magnification of a microscope Introductory Physics Homework 2
Angular Magnification Introductory Physics Homework 1
