Understanding Magnetism: Debunking the Myth of All Matter Being Magnetic
  • Context: Undergrad
  • Thread starter Thread starter darkchild
    Magnetic
The discussion revolves around the nature of magnetism in all matter, specifically addressing whether all materials exhibit some form of magnetism due to electron movement. Participants explore concepts related to diamagnetism and paramagnetism, and the implications of electron behavior on magnetic properties.
  • Some participants propose that all matter is at least slightly magnetic due to electron movement, even if imperceptibly.
  • Others argue that while all materials exhibit diamagnetism, this does not imply that they generate a magnetic field themselves, as the random movement of electrons typically cancels out their magnetic moments.
  • One participant mentions that diamagnetism is a weak response present in all materials, while paramagnetism is associated with unpaired electrons and results in attraction to magnetic fields.
  • There is a suggestion that the concept of electron orbits as tiny currents leads to the idea that all materials respond to magnetic fields.
  • Some participants express uncertainty about the terminology used to refer to the original poster in a thread.
Participants generally agree that all materials respond to external magnetic fields, but there is disagreement regarding the implications of this response and whether all matter can be considered magnetic in the same sense.
There are unresolved questions regarding the definitions of magnetism and the conditions under which different types of magnetic behavior manifest in materials.
darkchild
I was under the impression that everything was at least slightly, even if imperceptibly, magnetic because all matter that is not at absolute zero contains currents in the form of electron movement within its atoms. Is this correct?
hi darkchild! :smile:
Yes, that's basically correct, but I don't think it has anything to do with currents of electrons.
All materials are slightly diamagnetic, and all materials (I think) with unpaired electrons are paramagnetic.
Diamagnetism comes from the dipoles of paired electrons (paired either between two atoms or within one atom … see http://en.wikipedia.org/wiki/Electron_pair" ), and is weakly present in all materials. Diamagnetic materials are repelled by magnetic fields, and lines of magnetic flux curve away from them.
From http://en.wikipedia.org/wiki/Diamagnetism" …
Diamagnetism is a very general phenomenon, because all paired electrons, including the electrons of an atom, will always make a weak contribution to the material's response. However, for materials that show some other form of magnetism (such as ferromagnetism or paramagnetism), the diamagnetism is completely overpowered. Substances that mostly display diamagnetic behaviour are termed diamagnetic materials, or diamagnets. Materials that are said to be diamagnetic are those that are usually considered by non-physicists to be "non-magnetic", and include water, wood, most organic compounds such as petroleum and some plastics, and many metals including copper, particularly the heavy ones with many core electrons, such as mercury, gold and bismuth.
… the term "diamagnetism" was coined by Michael Faraday in September 1845, when he realized that all materials in nature possessed some form of diamagnetic response to an applied magnetic field.​
Paramagnetism comes from the dipoles of unpaired electrons, and paramagnetic materials are attracted by magnetic fields … see http://en.wikipedia.org/wiki/Paramagnetism" .
Paramagnetism and diamagnetism describes how something responds to an external magnetic field,but what darkchild asks is whether all matter generates magnetic field itself
The answer should be no,because the movement of electrons is random and hence their magnetic moment normally will be canceled out.
By the way,how do you guys refer to the first one to post in a thread?I'm a Chinese,not familiar with slang.
I was thinking that all material is magnetic (responds to a magnetic field) because electron orbits are tiny currents, and magnetic fields exert forces on currents.
We call it the original poster, abbreviated OP on some forums, but I haven't seen it used much here.
Well,it seems to be I who misunderstood you.
Everything does respond to external magnetic fields
  • · Replies 74 ·
15K
  • · Replies 18 ·
  • · Replies 27 ·
