Understanding the Relationship Between Time and Speed: A Confused Exploration
  • Context: High School
  • Thread starter Thread starter Chaz666
    Relative Speed Time
The discussion revolves around the relationship between time and speed, particularly exploring the implications of the equation speed = distance/time. Participants express confusion about how time behaves when no distance is traveled and the nature of time as a dimension in relation to speed and motion.
  • One participant expresses confusion about the equation speed = distance/time, questioning if time continues normally when no distance is traveled.
  • Another participant points out that if distance is zero, speed is zero, but time can still be any value, suggesting a distinction between speed and the passage of time.
  • A participant clarifies that the equation relates to the time taken for events to occur rather than the nature of time itself.
  • Some participants discuss the concept of time as a dimension that never stops, with every point in space having a world line, implying that motion is always present in some form.
  • There is a suggestion that traveling at light speed could theoretically result in zero elapsed time, but this is countered by the assertion that reaching light speed is impossible according to relativistic physics.
  • One participant attempts to explain the relationship between speed and time, suggesting that traveling faster results in time dilation relative to others, but this perspective is met with skepticism and further questioning.
  • Another participant reflects on the dimensionality of space and time, mentioning concepts from higher-dimensional theories, though they express uncertainty about the specifics.
Participants exhibit a range of views on the relationship between time and speed, with no consensus reached. Some agree on the basic definitions and implications of the speed equation, while others challenge or refine these ideas, leading to ongoing confusion and debate.
Participants highlight the complexity of the concepts involved, including the nature of reference frames and the implications of relativistic effects on time. There are unresolved questions regarding the definitions and interpretations of dimensions in physics.
Chaz666
ok, I am looking for some help, really confused. I am also kind of talking out load a bit, but typing.
Speed = distance / time
i don't know how i thought of it, or if it is correct, (probably horrifically wrong), but, if time is relative to speed, if no distance is traveled, will time continue normally, as it is relative to speed.
i mean no distance, as in none, which will require movement, as the planet is rotating, the galaxy moving through space, gravity is still in effect, etc. no distance will be covered, so speed will speed = time. now I am very confused.
can anybody make sense of my blithering an help explain anything about changing the rate of time. actually, thinking about it, this wouldn't work at all. now I am off the scale of confusion.
cheers!
If s=d/t, and d=0, then s=0, but t could be anything.
0=0/1
0=0/512
0=0/738367464909489048
0=0/0.000001
And so on.
That equation isn't about the passage of time itself, it is only about the time it takes for certain events to occur.
oo ar! how did i not see that.
cheers!
As far as I know, time is one of the 4 Dimensions that never stops, whereas one may sit at a specific point in 3D space in some reference frame. Every point in space has a world line so there is always that "motion."
The standard velocity = distance/time formula refers to the proper distance between two points (which is the same in all frames of reference divided by the time it takes to get there.
I suppose it is possible to conceptually think of traveling at lightlike speed so the elapsed time from A to B would be zero but by the relativistic momentum equations, it is impossible to get to the speed of light and one would wlays remain in the timelike area of the time-distance graph.
May i know what the other 3 dimensions are?
i think its like a box, 1 dimension would be a point, two a line, & 3 are depth, height & width.
unless there different for complicated physics...
the 4th is time, and i think einstein said there's 10 (or is it 11?) dimensions. gravity is thought to penatrate all of them, therefore it is so weak in comparison. (lol penatrates all of them). gravity is so weak in comparison, for example, the whole weight of the Earth pulling down on a little fridge magnet, yet its being held up by magnetic force.
i watch too much tv.
feel free to correct me :D
I was thinking of the ordinary cartesian x, y, z dimenesions (no matter what "angle" the frame of reference is in space. I know there is no absolute x, y, or z.
As far as ten dimensions, that is way out of my pay grade.
cheers!
Time is distance as much as time is not distance. If there was no such thing as distance there would be no such thing as time as you would travel everywhere instantly. Hence time is always greater than distance.
If time was less than distance time would start going backwards as you would complete your journey before you started it. The reason you can slow down time however in comparison to someone else is as follows.
Driver a and b start a 100 km journey all variables remaining constant except speed. Driver a travels at 100 km/h and driver b travels at 50 km/h. For the time that driver a is traveling time slows down for him/her in comparison to driver b otherwise he would not be able to complete his/her journey in half the time.
The first argument is driver a was traveling faster. Problem with that argument is that speed is simply time taken to travel a distance. Hence speed is not separate from time and distance because speed is time and distance. They are both the same.
Second argument will again be driver a was traveling faster. Replace traveling faster with slowing down time and you have what speed really is. Slowing down time.
A better example of slowing down time is the lesson I got in high school teaching that if I accelerated away from the Earth in a radius at a constant rate for 200 years, upon arriving back the Earth would have aged by 40,000 years. The reason is very simple. Because I was traveling distance in far less time than everyone else on the face of the planet time slowed down for me in comparison to everyone else on the face of the earth.
In that equation time is inversely related to speed
No, no ... time will continue normally anyway. Actually, time dilates with increasing speed relative to an inertial frame of reference using the moving object as the center of a second or moving FOR. There is no absolute inertial frame of reference. The original statement is true as depicted here [speed = distance/time] with reference to a frame of reference which is inertial. Any FOR can be chosen as inertial but once chosen, it must be "stuck with." Time continues in that FOR on and on, as well as any other FOR whether an object "stands still" in relation to that FOR or not.
Speed does not equate to time as you stated. If no motion in that FOR, time still proceeds in that FOR even though the object in question may be "standing still" in that FOR.
All the above relates to FORs that are NOT accelerating or decelerating. But, that's another story.
I hope this answers your specific question.
stevmg
  • · Replies 16 ·
  • · Replies 29 ·
