of which i thought was an ellastic collision problem
  • Thread starter Thread starter rottenapple
    Collision
The discussion revolves around an elastic collision problem involving two balls of equal mass, where one ball is initially moving at 12 m/s. Participants are exploring the application of conservation laws to determine the final velocity of the moving ball after the collision, particularly questioning the use of momentum conservation in elastic collisions.
  • Participants discuss the relevance of conservation of momentum and energy in elastic collisions, with some expressing confusion about why momentum conservation applies in this context. There are inquiries about the necessary equations and approaches to solve the problem effectively.
Some participants have provided clarifications regarding the principles of conservation of momentum and energy, indicating that momentum conservation is valid for all types of collisions, while energy conservation is specific to elastic collisions. However, there is still uncertainty among some about how to apply these principles to the problem at hand.
Participants are grappling with the definitions and applications of conservation laws in the context of elastic versus inelastic collisions. There is a mention of a numerical answer provided in a textbook, which adds to the complexity of understanding the underlying concepts.
rottenapple
Ball A moving at 12m/s collides elastically with ball B as shown. If both balls have the same mass, what is the final velocity of ball A? ***theta = 60***
Ui + Ki = Uf + Kf
I could only think of the above equation when I read elastic collision. However, the solution in the back of the book suggested using conservation of momentum, which I thought is only applicable to inelastic collision. The numerical answer is 6m/s which can be figure out using mv = mv and breaking it down to x and y components.
I can see how they get to the numerical answer but I am lost as to why? Can someone please explain why I would use the formula for conservation of momentum? And also, I'm at a complete loss on how to approach a problem like this so can you also explain what I would need to solve the problem if it is an elastic collision?
Thank you!
Conservation of momentum applies to all collisions. Conservation of energy applies to only elastic collisions.
So in summary,
Elastic:
[tex]K_i + U_i = K_f + U_f[/tex]
[tex]\vec{p}_i = \vec{p}_f[/tex]
Inelastic:
[tex]\vec{p}_i = \vec{p}_f[/tex] only
The forces due to the collision among particles(interior forces) are always larger than exterior forces, and they are so large that we can always omit the exterior forces. According to Newton's second law, F=d(mv)/dt, if F(exterior force) is zero , mv(momentum) must be a constant, i.e. momentum is conservertive. So the conservertion of momentum on collision is always valid.
Ui + Ki = Uf + Kf
Thank you!
For elastic collision, you may use both law of conservation of momentum and law of conservation of energy.
Ui + Ki = Uf + Kf
For inelastion collision , you can use only law of conservation of momentum. In inelastic collision , energy lost or gained. If you want to use law of conservation of energy,
Ui + Ki= Uf + Kf +energy lost
  • · Replies 16 ·
