Connection-oriented TCP
by lostinxlation
Tags: connectionoriented
lostinxlation
lostinxlation is offline
#1
Jun11-10, 05:29 AM
P: 38
Hi
I was reading the network book the other day and it said TCP was a connection-oriented protocol, and I'm now puzzled with what connection-oriented means in this instance.
I understand what connetion-oriented means in general. In the data link layer, connection-oriented communication such as ATM, Frame-Relay and telephone conversation set up the communication path first, transfer the data along that path, and tear down the path after the data transfer is done. The data flows on the same path which is set up in advance. It's very clear what connection oriented means in such a case, but I can't see a clear picture about connection-oriented in transport layer, TCP.
TCP(or any transport layer entities) doesn't specify the communication path, right ? How could TCP be connection-oriented ?
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
waht
waht is offline
#2
Jun11-10, 05:04 PM
P: 1,636
Quote Quote by lostinxlation View Post
Hi
TCP is a bit sophisticated protocol which ensures that all data packets are received. If some particular packet is lost TCP will ask the transmitting end to send it again until all packets are received in full. To accomplish this the two-ends have to talk to each other back and forth. In order to do that they have to be initialized that a TCP is to be used. That's why it's called connection-oriented.
Register to reply
Related Discussions
Spin connection vs. Christoffel connection High Energy, Nuclear, Particle Physics 3
Theoretical-oriented MSc in the UK Academic Guidance 7
natural scientists would learn OOP General Physics 0
natural scientists should learn OOP General Physics 0
Oriented Manifold Introductory Physics Homework 5
