Calculating Momentum Change in Elastic Collisions
  • Thread starter Thread starter superaznnerd
    Strange
The discussion revolves around calculating the change in momentum of a ball that falls from a height and collides elastically with the floor. The problem involves concepts from mechanics, specifically momentum and elastic collisions.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the initial and final momentum of the ball, questioning the interpretation of elastic collisions and the implications for momentum change. Some participants suggest considering the direction of momentum and the definition of elastic collisions.
The discussion is exploring various interpretations of the problem, particularly regarding the change in momentum during the impact. Some participants have provided insights into the nature of elastic collisions and the role of the coefficient of restitution, while others are seeking clarification on the distinction between change in momentum and change in magnitude of momentum.
There is some confusion regarding the wording of the problem, particularly in distinguishing between change in momentum and change in magnitude of momentum. Participants are also considering the implications of the collision being elastic.
superaznnerd
a ball of 2kg falls from rest froma 5m height and collides elastically with the floor below. what is the magnitude change in the object's momentum?
I did S=So+.5aT^2
I solved for the time it takes to reach the ground, which is 1 second.
Next, I figured out that the velocity on impact with ground is 10m/s
I did 10m/s *2kg = 20kgm/s
however, the answer is 40kgm/s. Can someone explain? thanks
You have the initial momentum, you need to get the velocity after impact to get the final momentum.
But problem asked the change in momentum.
Impulse=change in momentum=Ft=mg*∆t
They want the change in momentum during the impact with the floor, not during the initial drop.
Think what "elastically" means.
I think elastically means after collision the ball moves up. If we consider this, we need coefficient of restitution.
The coefficient of restitution = 1 for an elastic collision.
Please let the OP solve the problem now.
e=1 for perfectly elastic collision. I mean before collisin and after collision speed are the same for e=1. Actual case is not perfectly elastic.
Disagreed. From Giancoli's book Physics (5th ed.): "a collision, in which total kinetic energy is conserved, is called an elastic collision". And reading further: "collisions in which kinetic energy is not conserved are said to be inelastic collisions", and "if two objects stick together as a result of a collision, the collision is said to be completely inelastic."
now I get the answer is 0. right before the collision it is 20kgm/s down. right after it is 20kgm/s up. Thus, there is no change in magnitude of momentum...
rebelly: can you explain how the stuff you wrote is relevant??
Hm, could be my English fails me here, but looks like you are right. Momentum magnitude doesn't change, even if momentum changes by 40 kgm/s. But I can be wrong.
What you posted is a direct quote of the question wording, or was it translated?
You can safely ignore discussion with inky.
But there is a change in the direction of momentum. Momentum is a vector, so there is a change in the momentum. Hint: express the upward momentum as positive, and downward as negative.
It was addressed to stuff inky posted, don't worry about it. :smile:
Okay, I think I see the source of confusion here.
They are asking you to first find the change in momentum, and then get the magnitude of that change. It is not asking for the change in the magnitude of momentum.
that sounds right ill ask my teacher 2moro
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 32 ·
