Register to reply
Angle in a 3-D Parallelogram
by ctg7w6
Tags: angle, parallelogram
Share this thread:
ctg7w6
#1
Jun14-10, 02:15 PM
P: 12
Parallelogram in 3d with vectors. Points: A(2,-1,4); B(1,0,-1); C(1,2,3); D(2,1,8)
I need the interior angle at B in degrees.
2. Relevant equations
cos(theta) = (Vector1 dot product vector2) / (magnitude of v1 * magnitude of v2)
3. The attempt at a solution
I used vectors BA and BC. I got 39 degrees. The answer sheet that I have uses AB and BC as the vectors and gets 140 degrees. Which vectors should I use? The picture in the homework makes the angle at B look like one of the smaller angles in the parallelogram, but I know you shouldn't trust pictures, because they might not be drawn to scale.
So, I know how to do the problem, I just don't know which vectors are the correct ones to use. Could someone also explain WHY the particular set of vectors should be used instead of the other set? Thank you very much!
Phys.Org News Partner Science news on Phys.org
'Office life' of bacteria may be their weak spot
Lunar explorers will walk at higher speeds than thought
Philips introduces BlueTouch, PulseRelief control for pain relief
Dick
#2
Jun14-10, 04:18 PM
Sci Advisor
HW Helper
Thanks
P: 25,235
You did it right. The book did it wrong.
ctg7w6
#3
Jun14-10, 04:28 PM
P: 12
Thank you! That problem has been eating at me for the past few days and driving me nuts!
Register to reply
Related Discussions
Angle of incidence, angle of refraction and angle of reflection Introductory Physics Homework 1
Parallelogram homework help Calculus & Beyond Homework 13
Vectors that constitute the diagonals of this parallelogram Advanced Physics Homework 6
Parallelogram proof Precalculus Mathematics Homework 1
Parallelogram Help General Math 2
