| Thread Closed |
Help required for surface reflection circuit (IR-LED/ PHOTODIODE) |
Share Thread | Thread Tools |
| Jun14-10, 02:20 PM | #1 |
Hi
I am new to this forum but have been interested in reading many threads and would like to know if any of the experts could help. I am looking to make a circuit that I can measure different output levels of a photodiode from the ammount of "signal" reflected onto it from a particular glass surface My idea is to set the angle of the transmitter / receiver to get the optimum reading on a known surface coating on the glass, I would then like to measure a range of coatings and see if I can establish a significant measurable difference between them. Ideally the transmitter and receiver would be about 5cm apart and I coulkd make some sort of light tube to optimize the reflected signal if possible. I am looking for advice on a circuit so that I can measure the output of the photodiode as I do not want to use it as a switch like high or low , I want to be able to measure the output in mV so that I can then process the different levels into some meaningful data. I would also like advice if it would be better to use a very bright LED to reflect off the glass or an infrared LED? Sorry if I have not explained myself very well but I hope someone can understand what I want to do. Thanks in advance |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Help required for surface reflection circuit (IR-LED/ PHOTODIODE)
| 4-20mA photodiode circuit | Advanced Physics Homework | 0 | ||
| Photon reflection from a metal surface | Atomic, Solid State, Comp. Physics | 1 | ||
| Circuit Required | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Slow photodiode circuit | Electrical Engineering | 4 | ||
