Work required to pump water out of conical tank
by akbar786
Tags: conical, pump, required, tank, water, work
akbar786
akbar786 is offline
#1
Jun14-10, 09:37 PM
P: 18
Find the work done in pumping all the water out of a conical reservoir of radius 10ft at the top and altitude 8ft if at the beginning the reservoir is filled to a depth of 5ft and the water is pumped just to the top of the reservoir.
2. Relevant equations
None
3. The attempt at a solution
This is my work so far. I am taking the integral from -8 to -3. The top center of the cone is on (0,0). I have the integral going from -8 to -3 of (100 pi) *(62.4) (0-y) dy. The 100 is from the radius squared. The (0-y) is the distance the water has to travel up any given y. Any help?
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
Dick
Dick is offline
#2
Jun14-10, 10:03 PM
Sci Advisor
HW Helper
Thanks
P: 25,168
You want to integrate pi*r^2*(-y)*dy from -8 to -3, right? So you want to express r as a function of y, don't you? Why are you using 100, the radius squared at the top and where did 62.4 come from?
akbar786
akbar786 is offline
#3
Jun14-10, 10:22 PM
P: 18
Quote Quote by Dick View Post
62.4 is the density of water the teacher wanted us to use.I decided to keep all my numbers positive which will also make it much easier to integrate.Here is my new integral with expressing r as a function of y. 62.4*pi * integral from 0 to 5 of ((5/4y)^2) * (8-y)
8-y is the distance the water has to travel given the generic y and on each of those y's the radius will be 5/4 of the y term. Is this right? I am solving for work and 62.4 is my density for water
Dick
Dick is offline
#4
Jun14-10, 10:26 PM
Sci Advisor
HW Helper
Thanks
P: 25,168
Quote Quote by akbar786 View Post
Now that looks right to me. Putting the origin at the bottom does make it much less confusing.
akbar786
akbar786 is offline
#5
Jun14-10, 10:55 PM
P: 18
Awesome, thanks a lot for your help.
Register to reply
Related Discussions
Calculate the work to pump water out of tank Introductory Physics Homework 1
Work needed to pump water out of spherical tank Calculus & Beyond Homework 3
Work required to pump - Very tricky Calculus & Beyond Homework 5
Optimization question - water in a conical tank Calculus & Beyond Homework 1
Water Pressure in Conical Tank Question Engineering Systems & Design 3
