Thread Closed
Revolving a tank around the y axis: Work needed to pump water
Share Thread Thread Tools
Jun20-10, 01:14 PM   #1
1. A tank is formed by revolving y = 3x^2, x = [0,2] around the y axis is filled to the 4 feet point with water (w = 62.4 lb/ft^3). Find the work necessary to pump the water out of the tank over the top.
I got the integral being from a = 0 and b = 4 and integrating [(12y-y^2)/3]dy with w and pi as constants outside of the integral.
And after the integration I got:
224/9 pi (62.4)
And when I multiplied the 62.4 out it came out to be 1553.066 pi
Would this be correct? Just seems bit of a weird number?
[I asked this question earlier...and received help on it on an earlier thread, but I just wanted to see if the numbers I got are correct]
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jun20-10, 02:16 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
At each y, the figure rotated around the y-axis is a disk or radius [itex]x= (y/3)^{1/2}[/itex] and so has area [itex]\pi x^2= (\pi/3)y[/itex] and a very thin disk of thickness dy would have volume [itex](\pi/3)y dy[/itex].
The weight of that disk is [itex](\pi w/3)y dy[/itex] and must be lifted the remaining 12- y feet so the work done in lifting just that disk is (force times distance) [itex](\pi w/3) y(12- y)dy[/itex].
Integrate that from y= 0 to y= 4- that appears to be exactly what you have done!
Jun20-10, 02:41 PM   #3
Quote by HallsofIvy View Post
Wow. Ok.
Thanks! The number just seems really weird! Haha.
Thats all!
Thanks though! :]
Thread Closed
Thread Tools
Similar Threads for: Revolving a tank around the y axis: Work needed to pump water
Thread Forum Replies
Work required to pump water out of conical tank Calculus & Beyond Homework 4
Calculate the work to pump water out of tank Introductory Physics Homework 1
Work needed to pump water out of spherical tank Calculus & Beyond Homework 3
Work: Tank Of Water Calculus & Beyond Homework 5
Difficulty with washer method when revolving around axis other than y or x axis. Calculus & Beyond Homework 2
