How to Solve Inverse Trig Functions Without a Calculator?
This discussion focuses on solving inverse trigonometric functions without a calculator, specifically examples like sec(arctan 2) and cos(2arcsin(5/13). The method involves constructing right triangles based on the definitions of the trigonometric functions. For sec(arctan 2), a right triangle is drawn with the opposite side labeled as 2 and the adjacent side as 1, allowing the hypotenuse to be calculated using the Pythagorean theorem. This approach enables the calculation of sec(A) directly from the triangle's sides.
  • Understanding of inverse trigonometric functions
  • Knowledge of right triangle properties
  • Familiarity with Pythagorean theorem
  • Basic trigonometric identities
  • Study the derivation of trigonometric identities
  • Practice constructing right triangles for various inverse trigonometric functions
  • Learn how to apply the Pythagorean theorem in trigonometric contexts
  • Explore more complex inverse trigonometric problems without calculators
Students, educators, and anyone interested in mastering trigonometry, particularly those looking to solve inverse trig functions manually without relying on calculators.
gech
Supposing I need to solve a problem like: sec(arctan 2) or cos(2arcsin(5/13)), is there a method I could use that would not require a calculator? What I mean is that for an example like tan(arccos .5), the answer is "simple" because I know the arc cosine of .5 is pi/3 and then the tan of pi/3 is the squareroot of 3. But in a problem like the two above, how would I go about doing this where the numbers are more complicated and I want to do it by hand? Or is it impossible without the use of a calculator?
Here's one way: In the case of sec(atan(2)) draw a right triangle and label one of the angles, say A. Label the side opposite A with 2 and the side adjacent to it with 1. Clearly, A is an angle whose tangent is 2. What's the secant of this angle? Use Pythagoras to find the length of the hypotenuse and divide it by 1 (adjacent side) to find sec(A) = sec(atan(2)).
You can do similar things for your other example by applying well known trig identities.
I see what you're getting at. Thank you.
  • · Replies 40 ·
