The Thousand Locker Problem: How Many Remain Open?
  • Context: High School
  • Thread starter Thread starter PRodQuanta
The discussion revolves around the "Thousand Locker Problem," where participants explore how many lockers remain open after a sequence of students toggle the state of lockers based on their number. The scope includes mathematical reasoning and number theory concepts related to factors and perfect squares.
  • Some participants clarify that the problem involves toggling lockers based on multiples, not factors.
  • One participant suggests that 31 lockers will remain open, citing that only perfect squares have an odd number of factors.
  • Another participant explains that most numbers have an even number of factors, with perfect squares being the exception.
  • There is a discussion about the reasoning behind why only perfect squares remain open, with references to the number of times each locker is toggled correlating to its factors.
  • Some participants express confusion about the reasoning and seek clarification on how the toggling process works.
  • One participant incorrectly asserts that only locker one would remain open, which is challenged by another participant who provides a counterexample with locker four.
Participants generally agree that perfect squares remain open, but there is disagreement regarding the reasoning behind the toggling process and the implications for other lockers. Some participants express uncertainty about the mathematical principles involved.
There are unresolved questions about the clarity of the problem statement and the mathematical proofs provided. Some participants express confusion about the underlying concepts of factors and toggling lockers.
This discussion may be useful for individuals interested in mathematical puzzles, number theory, or those looking to understand the principles behind the Thousand Locker Problem.
PRodQuanta
You have a thousand kids that go to high school. In this school, there are 1000 lockers, so each kid has a separate locker. Now, All the kids , numbered 1-1000 line up outside of the school.
The first kid comes in a opens all the lockers.
The second kid comes in a shuts all of the even number lockers.
The third kid comes in and changes (if it's open, he shuts it, and vice versa) all the lockers that are multiples of 3.
The forth kid comes in and changes all the lockers that are multiples of 4.
And so on and so forth, with the 1000th kid changing the locker that is a multiples of 1000.
The question? After the 1000th kid changes the locker, how many lockers are left open?
Make sure you prove it.
Paden Roder
P.S.-If you need any more explanation, tell me. I may have left some small details out on accident.
Mathematics news on Phys.org
I think you mean 'multiples' when you say 'factors'.
My guess : 31
A fairly common number theory result states than the only numbers with an odd number of factors (in/ex cluding 1 and itself) are perfect squares. This result is not hard to prove.
[tex]If ~~n=p_1^{k_1}p_2^{k_2}p_3^{k_3}...p_r^{k_r}[/ tex]<br /> <br /> [tex]No. ~of~divisors~\tau (n) = (k_1+1)(k_2+1)(k_3+1)...(k_r+1)[/ tex]<br /> <br /> This can be odd only if all k's are even, implying that n is a perfect square.<br /> <br /> PS : The LaTeX wouldn't change color, so I put in a space between / and TEX to deformat it.[/tex][/tex]
Sorry, I read (and posted) the problem wrong. I meant multiples, not factors. Anybody agree? Disagree?
Paden Roder
this is what Gokul43201 meant:
[tex]If ~~n=p_1^{k_1}p_2^{k_2}p_3^{k_3}...p_r^{k_r}[/tex]
[tex]No. ~of~divisors~\tau (n) = (k_1+1)(k_2+1)(k_3+1)...(k_r+1)[/tex]
Well, this post hasn't been up long enough. I would have given it more time...
I wonder why Gokul is calling it a guess that's a perfect impromptu approach ... ofcourse there is no point to disagree
Oh, just so often, when you're absolutely positive about something and you're willing to bet your salary on it, someone will come along and show you where you wrote 2-1=3.
It's just for safety, I guess, since I did that in a bit of a hurry...and actually checked that the numbers are right only much later.
Paden Roder
Select to see:
31 will be open (square root of 1000 is 31 point something). 31 doors had an odd number of students come along - 969 doors had an even number of students come along.
Most numbers have an even number of factors.
Example: 18 = 18 x1, 9x2, 6x3. Factors are 1, 2, 3, 6, 9, and 18.
The only exception are perfect squares. The fact that you're multiplying a number of by itself gives it an odd number of factors.
Example: 16 = 1x16, 2x8, 4x4. Factors are 1, 2, 4, 8, and 16.
Since 31 is the largest number that can be squared and still be less than 1000, there are 31 perfect squares between 1-1000 (counting 1 which only has 1 as a factor).
[/color]
Good job. All perfect squares will be left open. That's 31.
Paden Roder
sorry to revive an old thread, but how did you figure that out? that is just so above me. why is it that every other locker will be closed? because only the squares will not be changed an even number of times?
Can you see that the number of times that a locker gets switched is equal to the number of factors that the corresponding number has?
After that, it's a matter of figuring out that the only numbers that have an odd number of factors are squares. That's pretty easy to prove, but I'm not sure how to come up with it as a hypothesis.
All the lockers would be closed except locker one because the multiples of a number are the number times one, times two, ect. numbers times one are the number so all lockers would be closed but locker number one.
That's false. Consider locker 4. The first kid will open it, the second kid will shut it, the third kid will leave it shut, the fourth kid will open it. The fifth, sixth, ..., thousandth kid will leave locker 4 open.
  • · Replies 20 ·
9K
  • · Replies 16 ·
13K
