Solving Uncertainty Problem with .7g Lateral Acceleration
  • Thread starter Thread starter purduegrad
    Uncertainty
The problem involves estimating the experimental uncertainty in lateral acceleration measurements for vehicles tested on a skidpad. The context includes a specified skidpad diameter and deviations in vehicle path and speed measurements.
  • Participants discuss the relationship between acceleration, radius, and speed, with some attempting calculations based on given parameters. Questions arise regarding the need for partial derivatives and the relevance of time in the calculations.
There are multiple interpretations of the problem, with some participants arriving at different percentage results for uncertainty. Guidance has been offered regarding equations and substitutions, but clarity on the final answer remains elusive.
Participants note the lack of information regarding time measurements, which is critical for certain calculations. There is also a mention of specific measurement uncertainties that need to be considered.
purduegrad
Here's the problem:
A magazine publishes lateral acceleration capability from cars it tests. Measurements are made using a 150' diameter skidpad, the vehicle path deviates from the circle +/- 2 ft and the vehicle speed is read from a fifth wheel sensor measuring the system to +/- .5 mph. Then it says to estimate the experimental uncertainty if the reported lateral acceleration is .7g.
All I can think of is A=v^2/r...and some how i would have to cut the 150 diameter into 75 as a radius. I got 75 +/- .0133. then i found v = to 22.69, and you have to square that...I'm basically stumped...the answer is like 4.XX% :frown:
I did the calculation and I got 8%.
hmm well its supposedly like 4.45%, i have a feeling this has something to do with partial derivatives?
no, you don't need partial derivatives to solve it. Ill get back to you with the answer, by the way, how many feet in a mile?
5280 feet in mile
I Still can't get it, I get something liek 3.8%.
See if this helps
[tex]A = \frac{1.226r}{t^2}[/tex]
where
A = acceleration in g's
r = radius of track
t = time [in seconds] to complete 1 lap
This is how g's are calculated on a skidpad
re: http://www.carcraft.com/howto/53698/index7.html
yeah but I am not given any information about times
try substitution. T = d/v. The equation then becomes
[tex]A = \frac{1.226rv^2}{d^2}[/tex] Does that help?
Given the uncertainty of measurements in the quantities r and v, the answer is there. I agree with the 4.xxx% result, see what you get.
I'm still not following how to get that 4.45 answer, can you please elaborate for me?
  • · Replies 75 ·
15K
