Question about black holes and white dwarf
The discussion revolves around the sizes of various astronomical objects, specifically black holes, white dwarfs, neutron stars, and the sun. Participants explore the comparative diameters of these entities and clarify terminology used in the initial question.
  • Conceptual clarification, Technical explanation
  • One participant notes that the sun is about 100 times the diameter of Earth.
  • Another participant states that a white dwarf is roughly the same size as Earth, depending on its mass.
  • A neutron star is described as being about the size of a city, with a radius of approximately 10-15 km.
  • A black hole's size is indicated to be variable, depending on its mass.
  • There is speculation about the term "qatar," with suggestions that it might refer to either a quark-star or a quasar, with further explanations provided for both terms.
  • One participant emphasizes that a black hole is defined by its event horizon, which is a function of its mass.
  • A later reply clarifies that the original poster meant to inquire about diameters specifically.
Participants generally agree on the sizes of the astronomical objects discussed, but there is uncertainty regarding the term "qatar" and its intended meaning. The discussion does not reach a consensus on the interpretation of this term.
The discussion includes some ambiguity regarding the terminology used and the specific definitions of the astronomical objects, which may affect the clarity of comparisons made.
hager mahdy
hi
i want to ask aquestion
what is the biggest qatar:
black hole or white dwarf or nutron star or the sun
please i want to know the biggest one and then and then and the smallest one
thaaaank you very much
Space news on Phys.org
Well the word "qatar" doesn't make any sense, but it is clear what you are asking.
The sun is about 100 times as big (in diameter) as earth
A white dwarf is roughly the same size as the earth, depending on its mass.
A neutron star is about the size of a city, 10-15 km in radius.
A black hole can be any size, depending upon its mass.
I'm guessing he means either quark-star, or quasar.
Hager Mahdy, if you did mean Quasar, they are believed to be the active nuclei of distant galaxies, and therefore are black holes. If you meant Quark-Star (possibly a step between Neutron Star and Black Hole) then no one knows, but it would be more compact than the former, and less so than a black hole.
Remember that a black hole is best defined by its event horizon, which is purely a function of its mass, as Nicksauce said. They seem to get quite massive, especially AGNs.
thank you very much and iam sorry but i mean diameter
thaank you
  • · Replies 57 ·
  • · Replies 0 ·
  • · Replies 22 ·
  • · Replies 22 ·
