Proving Periodicity of Sin/Cos with Series Representation
  • Context: Graduate
  • Thread starter Thread starter astroultraman
    Representation Series
The discussion centers around proving the periodicity of the sine and cosine functions using their series representations. Participants explore various approaches to demonstrate both the periodic nature of these functions and the value of their period, specifically addressing the implications of using Taylor series and differential equations.
  • Some participants suggest using the Taylor series expansion of sine and cosine to establish their periodicity, proposing that the period must be 2π based on the use of radians.
  • Others argue that simply showing the series satisfies a differential equation does not directly address the OP's question about proving periodicity from the series itself.
  • A participant proposes using the definition of periodicity, f(x + P) = f(x), along with the binomial expansion to demonstrate periodicity, although they express concern about the complexity of this approach.
  • One participant mentions that proving periodicity directly from the series expansion appears challenging, suggesting that demonstrating any solution to the relevant differential equation has a period of 2π could be a viable alternative.
  • Another participant outlines a method involving the exponential function and its properties to derive the periodicity of sine and cosine, indicating a structured approach that includes defining the functions through their series representations.
Participants express differing views on the best method to prove periodicity, with no consensus on a single approach. Some support using differential equations, while others emphasize the need to work directly from the series representations.
There are unresolved complexities regarding the assumptions made about the functions and their definitions, particularly in relation to the interpretation of the argument in radians and the implications for periodicity.
This discussion may be of interest to those studying mathematical analysis, particularly in the context of series representations, differential equations, and the properties of trigonometric functions.
astroultraman
with the series representation of sin or cos as a starting point (you don't know nothing else about those functions), how to prove:
a. they are periodic.
b. the value of the period.
Are you talking about the Taylor series expansion of sin and cos?
If you are talking about them, then the period must be 2pi since the Taylor expansion is based on the use of radians as a measure of angles.
If something is periodic you can always check if f(x) = f(x+kP) where P is the period and k=0,1,2,3...
Show that the series expansions satisfy the differential equation that uniquely defines sine and cosine:
[tex]y'' = -y[/tex]
sine is the unique solution satisfying [itex]y(0) = 0[/itex] and [itex]y'(0) = 1[/itex].
cosine is the unique solution satisfying [itex]y(0) = 1[/itex] and [itex]y'(0) = 0[/itex].
You can differentiate the series term by term because they are power series that converge everywhere.
I don't think those replies do not show what the OP asks to show. The OP wants to know how to use the power series to demonstrate periodicity of the functions. Showing that the power series satisfy some other definition of cos and sin presumably defeats the purpose of the question.
All you know are that you have some functions s(x) and c(x), defined by their power series. x is just a dimensionless argument. It need not be interpreted as a radian. Even if you did interpret it as a radian, you cannot automatically deduce the period is [itex]2\pi[/itex]. [itex]\tan\theta[/itex]'s argument is in radians, but its period isn't [itex]2\pi[/itex].
[tex]y'' = -y[/tex]
Again, in terms of the OP's problem, that shows the functions s(x) and c(x) satisfy that differential equation, but under the conditions of the problem we don't know about the functions sin or cos, so this is in some sense the first discovery of these functions, and we haven't proven periodicity yet. Of course, perhaps this is the way it actually gets done - the method which I think the OP is asking for (see below) looks intractable to me.For the OP: what I might try, in place of showing the power series satisfy some other definition of sine or cosine, is to use the definition of periodicity, f(x + P) = f(x) and the binomial expansion. e.g.,
[tex]s(x+P) = \sum_{k=0}^\infty \frac{(-1)^k(x+P)^{2k+1}}{(2k+1)!} = \sum_{k=0}^\infty \sum_{m=0}^{2k+1} \frac{(-1)^k}{(2k+1)!}\frac{(2k+1)!}{m!(2k+1-m)!} x^m P^{2k+1-m}[/tex]
I would then switch the order of summation (you'll have to figure out how to change the limits appropriately), and write the series as
[tex]\sum_{m=?}^? \frac{x^m}{m!}\left[\sum_{k=?}^{?} \frac{(-1)^k}{(2k+1-m)!} P^{2k+1-m}\right][/tex]
Then, show that for P = 2pi this reduces to the original series. In principle I think this should work, but in practice it may be too hard to do. A quick attempt at it give me a hypergeometric function for the inner function, and good luck dealing with that... especially since there's a cosine in the argument! I may have screwed something up, though.
I suggested proving that the functions to which the series converge satisfy the indicated differential equation because there's no obvious way that I can see to prove periodicity directly from the series expansion.
Yes, you then have to show that any solution to the differential equation has period [itex]2\pi[/itex]. To do that is not entirely straightforward, but at least it can be done. See, for example, this thread:
https://www.physicsforums.com/showthread.php?t=274664
There's also a nice treatment in Knopp, "Theory and Application of Infinite Series." You can see the relevant section at Google Books, section 24, page 198. Hopefully this link works:
http://preview.tinyurl.com/2ddxs5f
Mute++
Rudin works all this out in the Prologue of "Real and Complex Analysis", so maybe you should just get a copy of the book and read it. Here is an outline of his approach:
1. Define [tex]\exp(z)[/tex] by its series representation (for complex z).
2. Deduce [tex]\exp(a) \; \exp(b) = \exp(a+b)[/tex]
3. Define sin and cos by [tex]\cos t = Re(\exp(i t))[/tex] and [tex]\sin t = Im(\exp(i t))[/tex]-- in other words, by their series representations.
4. Show there is a smallest positive [tex]t_0[/tex] such that [tex]\cos t_0 = 0[/tex].
Define [tex]\pi[/tex] by [tex]\pi = 2 t_0[/tex].
5. Show that [tex]\exp(z + 2 \pi i) = \exp(z)[/tex]
6. [tex]\exp(\pi i / 2) = i[/tex] and [tex]\exp(z) = 1[/tex] if and only if [tex]z / (2 \pi i)[/tex] is an integer.
7. [tex]\exp[/tex] is a periodic function with period [tex]2 \pi i[/tex]
Periodicity of sin and cos then follow.
  • · Replies 33 ·
  • · Replies 23 ·
