Deriving the Rotation Period of a Planet from Density
In summary: It should be 1.4 hours, not days.In summary, the discussion was about deriving an expression for the rotation period of a planet based on its density, assuming it is a perfect sphere with evenly distributed mass. The derived expression was T = \sqrt{(3*Pi)/(G*rho)}, which was found to be close to the actual rotation period of the Earth. However, it was clarified that this calculation does not take into account the angular momentum of the Earth-Moon system and that a torque is not needed to keep the Earth rotating. It was also mentioned that this expression can be used to estimate the minimum rotation period of a planet.
skullers_ab
It's a high school physics question that I remembered and need to understand for curiosity's sake. I'm stating the problem in my own words, so it is likely that I may be asking a wrong question. Here it is nonetheless:
Derive an expression that shows that the major variable affecting the rotation period of a planet is its density [assuming planet is a perfect sphere & mass is evenly distributed].
Newton's law of gravitation: F = G*M*m/r^2
Centripetal force: F = m*v^2/r and v = 2*Pi*r/T
Density: rho = m/v
Assuming the rotation is due to a centripetal force (which is due to the gravitational attraction of the surface mass and the rest of the planet's centre of mass) acting on the surface of the planet, I get this as my final expression for the period, T:
T = [tex]\sqrt{(3*Pi)/(G*rho)}[/tex]
(I'm unable to get (3*Pi) and (G*rho) in brackets like this, for Latex)
The problem is that when I substitute the value of the density of Earth (5515 kg/m^3), I don't get anywhere near the actual 24 hours that I should.
What number are you getting? I get about 1.4 days -- which seems pretty close to me based on the redumentary nature of the calculation...
BTW, the LaTeX is "\sqrt{\frac{3 \pi}{G \rho}}"
[tex]\sqrt{\frac{3 \pi}{G \rho}}[/tex]
See https://www.physicsforums.com/showthread.php?t=386951
Whoa! What centripetal force are you talking about here? (Hint: There is none.)
The Earth's rotation rate has the value that it does because the angular momentum of the Earth-Moon system is conserved.
Is this a complete coincidence then? I wondered about that before I posted.
I think the assumption in the problem is basically modeling the Earth as an ideal gas which his held together by its own gravity. So gravity is providing the centripetal force that keeps the planet rotating in uniform circular motion.
The model is clearly ridiculous for the Earth (which is why I'm surprized the calculation is even close). But maybe it is useful in modeling the gas giants or the rotation of galaxies?
Thank you for your responses folks.
@dulrich: The numerical value that I get for T is around 5062 seconds which are around 1.4 hours, not days. Please clarify if I've made an error in this. If not, then sadly it is quite off from 24 hours.
Also, thanks for the reference to LaTex usage, I'll keep that in mind.
@D H: Yes, I was doubtful about the same [the concept that centripetal force is involved]. I was starting to think the the planet's rotation was a combined effect of its angular momentum AND centripetal force [but now I guess, CF is totally out of the question]
I was reading more through Google, and read somewhere that based on the period of a satellite at the surface of a planet they can figure out the mean density of the planet. And then I came across this discussion:
http://www.spacekb.com/Uwe/Forum.aspx/astro/7649/Finding-minimum-rotation-period
From what I now understand, the formula I've stated is for calculating the minimum time period possible for a planet to rotate without breaking itself apart or the maximum velocity with which its surface can rotate. That would be the same as the velocity required to place a satellite in orbit near the surface of the Earth.
Hence, my understanding now is that if a satellite were to be placed in orbit at the surface, it would have a period of 1.4 hours [and a speed of 8km/s] for going around the earth. Am I correct in my inference?
Also, I managed to get my hands on the actual question which was in the paper. My mistake, I'd recalled the question incorrectly which led to my curiosity. Here it is:
The fastest possible rate of rotation of a planet is that for which the gravitational force on an object at the equator just provides the centripetal force needed for that rotation. The planet is assumed to be a sphere of uniform density. Show that the period is T = [tex]
[/tex]
For one thing the coincidence isn't as strong as you think:
[tex]\sqrt{\frac{3\pi}{G\rho}} \approx 1.4\,\text{hours}[/tex]
Good old google calculator: http://www.google.com/search?q=sqrt(3*pi/(G*earth+mass/(4/3*pi*(6378+km)^3)))
More importantly, a force (or rather, a torque) is not needed to keep the Earth rotating. The Earth has angular momentum due to its rotation. A torque would be needed to change the rotation rate.
Yeah, my bad. Sorry about the confusion on the calculation.
1. What is the period of Earth's rotation?
The period of Earth's rotation refers to the amount of time it takes for the Earth to complete one full rotation on its axis. This is approximately 24 hours.
2. How is the period of Earth's rotation measured?
The period of Earth's rotation is measured using a device called an atomic clock, which uses the vibrations of atoms to keep extremely accurate time.
3. Has the period of Earth's rotation always been the same?
No, the period of Earth's rotation has changed over time. It used to be shorter, but due to tidal forces from the moon, it has gradually slowed down. Scientists estimate that the Earth's rotation is slowing down by about 1.7 milliseconds every century.
4. Is the period of Earth's rotation the same all over the planet?
No, the period of Earth's rotation can vary slightly depending on your location on the planet. For example, at the equator, the rotational speed is faster than at the poles due to the Earth's shape and the Coriolis effect.
5. Can the period of Earth's rotation be affected by external factors?
Yes, external factors such as earthquakes, volcanic eruptions, and changes in the distribution of mass on Earth's surface can affect the period of Earth's rotation. These changes can be very small and difficult to measure, but they can have an impact on the Earth's rotation speed.
