Help Basic Rotational Dynamics Question
The discussion revolves around understanding the principles of rotational dynamics as they apply to car engine pulleys. Participants explore how to determine the torque required by different pulleys based on their dimensions and weights, as well as the implications of pulley geometry on torque calculations.
  • One participant seeks help in calculating which of the Bx pulleys will require more torque from Pulley A and how to determine the resulting torque on each pulley.
  • Another participant explains that if all pulleys are geometrically similar, the relationship between the pulleys can be expressed using equations for angular velocity and torque, noting that the moment of inertia for pulleys is approximately (1/2)MR² for solid cylinders.
  • A participant calculates the moment of inertia for each Bx pulley based on the assumption of similar geometries, providing specific values for B1, B2, B3, and B4.
  • One participant suggests that the estimate for torque is closer to (1/2)MR², but acknowledges that the exact geometry will affect this value.
  • A participant shares a link to a website for additional clarification on the topic.
Participants express varying degrees of certainty regarding the moment of inertia calculations and the impact of pulley geometry on torque. There is no consensus on the exact values or the best approach to calculating torque for the Bx pulleys.
Participants note that the moment of inertia can vary based on the specific geometry of the pulleys, and the calculations provided depend on the assumption of similar geometries. The discussion does not resolve the exact nature of these assumptions or their implications for torque calculations.
4getr34
Can anyone help me figure out this question? I swear this isn't homework! I am actually from a car forum and would like to understand some basic principles behind car engine pulleys.
Pulley A drives another pulley Bx via a belt.
Pulley A
diameter:15inches
weight: 1lbs
applied torque: 10lbs*1inch
Pulley B1
diameter: 5inches
weight: 0.5lbs
Pulley B2
diameter: 5inches
weight: .75lbs
Pulley B3
diameter: 7inches
weight: .25lbs
Pulley B4
diameter: 7inches
weight: .75lbs
Which of the Bx pulleys will require more torque from Pulley A to rotate? How do you figure this out? What is the resulting torque on each of the Bx pulleys?
thanks a lot!
Assuming all pulleys are geometrically similar, here is how you go about it.
Belts ensure that surface speed of all pulleys is identical. Id est,
[tex]R_A \omega_A = R_i \omega_i[/tex]
And consequently,
[tex]R_A \dot{\omega}_A = R_i \dot{\omega}_i[/tex]
And of course, the equation for angular acceleration and torque,
[tex]I_i \dot{\omega}_i = \tau_i[/tex]
The only problem is that there is no specific equation for moment of inertia, Ii for pulleys. It's going to be close to (1/2)MR² for solid cylinder, but it can be a little higher or lower depending on the geometry. This is where argument for similar geometries should come in. If all pulleys have similar geometries, then
[tex]I_i = c M_i R_i^2[/tex]
What that c is, doesn't really matter. It's a dimensionless constant. The important bit is that it should be the same for all pulleys. Using that, you should be able to express torque for each pulley in terms of angular acceleration of A, masses and radii of the pulleys, and this coefficient c. Then compare results. Good luck.
wow thanks a lot for the reply!
so if i understand correctly as long as the geometries on the pulleys are similar its basically I = MR^2
B1
I = 3.125 lbs * inch^2
B2
I = 4.6875 lbs * inch^2
B3
I = 3.0625 lbs * inch^2
B4
I = 9.1875 lbs * inch^2
i'm going to see if i can find out from the companies actual geometries but this is really interesting as B4 is my impression of a overweight underdrive pulley and I'm actually trying to decide between B3(underweight oversize) and B1 (stock) pulleys. thank you very much!
If you actually need an estimate on torque, it's closer to (1/2)MR². Whether it's a little more or a little less depends on exact geometry.
