Oxygen/Lambda sensor on two stroke
  • Thread starter Thread starter Jimmybrockman
    Sensor
The discussion focuses on integrating a lambda sensor into a two-stroke Yamaha motorcycle's exhaust system to monitor air/fuel ratios for a closed-loop fuel injection system. The participant considers the impact of two-stroke exhaust gases, including unburnt fuel and oil, on the lambda sensor's accuracy. While a narrow band lambda sensor is initially considered, the participant leans towards a wide band sensor for its broader range and linear output, which would better accommodate the unique exhaust characteristics of two-stroke engines. Additionally, the use of an exhaust temperature sensor is proposed as a supplementary measure to monitor optimal mixture conditions.
  • Understanding of lambda sensors and their operation
  • Familiarity with two-stroke engine mechanics
  • Basic electronics knowledge, including sensor integration
  • Experience with fuel injection systems and tuning
  • Research the differences between narrow band and wide band lambda sensors
  • Learn about two-stroke engine tuning techniques
  • Investigate exhaust gas temperature (EGT) monitoring methods
  • Explore closed-loop fuel injection system design principles
Motorcycle enthusiasts, engineers working on two-stroke engine modifications, and anyone involved in fuel injection system development will benefit from this discussion.
Jimmybrockman
I have a two stroke Yamaha motorcycle and I wish to fit a narrow band lambda sensor to the exhaust with the intention of monitoring air/fuel ratios and eventually designing and making a simple closed loop fuel injection system (with some open loop capabilities, until the sensor warms up or at full power).
I have most of the equipment I need e.g an analogue oscilloscope (digital storage scope would be better but oh well), prototyping boards, access to components and electronics experience including an A level in electronics.
My question is how do you think the lambda sensor would cope with two stroke exhaust gasses?
According to wiki:
"The sensor does not actually measure oxygen concentration, but rather the amount of oxygen needed to completely oxidize any remaining combustibles in the exhaust gas. Rich mixture causes an oxygen demand. This demand causes a voltage to build up, due to transportation of oxygen ions through the sensor layer. Lean mixture causes low voltage, since there is an oxygen excess."
So would the raw fuel that passes through the exhaust port during gas the exchange on a two stroke and the extra hydrocarbons from un-burnt two stroke oil affect the operation and readings of a lambda sensor to the point that it is unable to determine if the engine is actually running lean or rich?
Thank you very much
i think you ould be better off putting a exhaust temperature sensor on the header and monitoring the temp for optimum mixture..read the spark plugs because when you monkey with the fuel air ration you can lean out the mix and burn a piston..
Thank you for your reply, measuring EGT is very good idea I will adopt (as a way of double checking for leaned mixture) however it wouldn't give the accuracy and response I would be looking for as a feedback for my fuel injection project.
I have been thinking of dropping the narrow band sensor in favour for a wide band but these sensors are rarer and more expensive, however a wider range sensor can read a larger range of air/fuel ratios and a linear output sothe ability to compensate for errors due to un-burnt fuel etc would be easier.
I will fit a temperature sensor to the exhaust next week to get a feel for what are normal tempuratures for my bike at various loads and rpms and make a note of these.
  • · Replies 19 ·
11K
32K
17K
