| Thread Closed |
Penetration of certain objects |
Share Thread | Thread Tools |
| Jun25-10, 04:42 PM | #1 |
Hi, I'm new to physics forums and I was wondering how to calculate the force required to penetrate objects of varying densities, for example an arrow shot at a plank of wood with a density of approximately 1.2 x 10^3 kg/m^3. Lets assume the arrowhead and the plank are perpendicular at the site of impact. You can make reasonable assumptions. Also, if possible how would the calculation change if I wanted to penetrate, say, 10 cm of this wood?
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jun25-10, 06:05 PM | #2 |
Unfortunately, it's more complicated than that. It has to do with more than just density. You have to take into consideration the actual intermolecular forces of the substance you're shooting through.
For example, if it were just based on density, then it would be easier to shoot an arrow through a plank of oak (.85 x 10^3 kg/m^3) than it would be to shoot through an equal volume of water (1.0 x 10^3 kg/m^3), which I'm sure you know from experience not to be the case. In fact, if density alone determined resistance to penetration, then anything that floats in water would be easier to shoot through than the water itself! All things considered, there isn't a simple formula for this. So, sorry to shoot an arrow through your bubble, but welcome to PF! |
| Jun26-10, 02:15 AM | #3 |
What you need is to look at something about the lines of the strength of the material, in your case wood. What you want to look for would be the amount of pressure that a certain type of wood could withstand to a certain depth.
I think that is shear stress.....maybe..... |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Penetration of certain objects
| Length contraction (objects & space or objects only) | Special & General Relativity | 10 | ||
| During a tornado, softer objects are driven through apparently harder objects... | Introductory Physics Homework | 1 | ||
| Given 2n objects, number of ways to select n objects | Calculus & Beyond Homework | 1 | ||
| Why the black objects absorb more light and heat from the other color objects? | General Physics | 27 | ||
| EM penetration of physical objects | General Physics | 9 | ||
