Conducting sphere in a conducting spherical shell
A conducting sphere with a total charge of 6 microcoulombs is placed at the center of a conducting spherical shell, which also carries a charge of 6 microcoulombs. The charge on the inner surface of the shell is determined to be -6 microcoulombs, as the electric field within the conducting material must remain zero. Consequently, the total charge on the outer surface of the shell is calculated to be 12 microcoulombs, as it must account for both the charge of the sphere and the shell itself.
  • Understanding of Gauss's Law
  • Knowledge of electric fields in conductors
  • Familiarity with charge distribution in conductive materials
  • Basic concepts of electrostatics
  • Study the applications of Gauss's Law in electrostatics
  • Learn about electric field behavior in conductors
  • Explore charge distribution in spherical conductors
  • Investigate the implications of electric fields in different geometries
Students of physics, electrical engineers, and anyone interested in understanding electrostatics and charge distribution in conductive materials.
GreenDinos
A conducting sphere that carries a total charge of 6 micro C is placed at the center of a conducting spherical shell that also carries a total charge of 6 micro C .
(a) Determine the charge on the inner surface of the shell.
(b) Determine the total charge on the outer surface of the shell.
this seems like it shouldn't be too hard, but i guess i just don't understand the concepts well enough to figure it out...
I was thinking about where I would put field lines in this to understand what's going on- but all i can come up with is that inside a spherical shell there's no electric field...but there's a conducting sphere in there which throws that off. I'm not sure that would help anyway. I guess I'm just thinking- that since they both have + charges, the inside part of the shell would be...i dunno, -6 micro Coulombs...since the electrons would move to the charge??...and that maybe, since the charges are both radiating out- the outer surface would be 12 micro C? I am probably very wrong but this is why i am looking for help. anything would be much appreciated.
thanks
Gauss's Law
Welcome to PF!
Depends what you mean by "inside the shell". Inside the cavity the field will be zero only if there's no charge inside. Inside the conducting material of the shell itself--that's where the static electric field will always be zero. So imagine a Gaussian surface inside the conducting material.
thanks
Well, whether you know it or not you are exactly correct. Since the field within the conducting material is zero, the total charge within that Gaussian surface must be zero. That tells you the charge on the inner surface. And you know what the total charge is on the shell, thus you can deduce what the outer charge must be. Think it over.
Ah ha! that's a big help- that's basically what i was thinking but i couldn't find anything in my book that said it clearly. Thanks so much for your help!
  • · Replies 17 ·
  • · Replies 27 ·
