[Integrals] Just can't quite finish this
  • Context: Undergrad
  • Thread starter Thread starter Caldus
    Integrals
The discussion revolves around calculating a Riemann sum and the corresponding integral for the function (-x^2/3) - 7 over the interval [0, 4] using n subintervals. Participants explore various techniques for evaluating limits and integrals, including algebraic manipulation and the use of summation identities.
  • Homework-related
  • One participant presents a limit involving a Riemann sum and seeks assistance in simplifying it further.
  • Another participant suggests breaking limits into separate parts and checking algebra for errors.
  • A different participant provides a step-by-step breakdown of the limit calculation, indicating a potential error in the original approach.
  • There is a discussion about the correct application of the distributive law in the context of summation.
  • One participant expresses uncertainty about their algebra skills and receives advice to review foundational concepts.
  • A later reply highlights the realization that the area under the curve corresponds to a quarter circle, indicating a shift in understanding.
Participants do not reach a consensus on the correctness of the initial calculations, and there are multiple competing views on the approach to solving the problem. The discussion remains unresolved regarding the final evaluation of the integral.
Some participants mention potential errors in algebraic manipulation and the need for careful application of mathematical principles, but no specific assumptions or limitations are resolved.
This discussion may be useful for students or individuals interested in calculus, particularly in understanding Riemann sums, limits, and integral evaluation techniques.
Caldus
Hi,
I am trying to solve this problem:
Find the right rieman sum and the integral (using the definition of integral) of:
(-x^2/3)-7 on the interval [0,4] using n subintervals.
So:
lim n->infinity of [sigma from i = 1 to n of (-(4i/n)^2/3)-7]*4/n
= lim n->infinity of [sigma from i = 1 to n of (-4i^2/3n^2)-7]*4/n
= lim n->infinity of [sigma from i = 1 to n of i^2 - 7]*(-16/4n^3)
= lim n->infinity of [sigma from i = 1 to n of i^2] - 7n*(-16/4n^3)
= lim n->infinity of ((n(n + 1)(2n + 1))/6)-7n*(-16/4n^3)
I don't how to go any farther with this...
Thanks for any help.
Well, you have lots of techniques for working with limits. For instance, you can usually break lim (A + B) into lim A + lim B. You can combine your fractions into a single fraction, and use what you know about limits of rational functions. If you think the result looks unreasonable, you can check your algebra. Et cetera.
OK here we go:
= lim n->infinity of ((2n^3+3n^2+n)/6)+(112n/4n^3)
= lim n->infinity of ((2n^3+3n^2+673n)/24n^3)
= (1/12)+(1/8n)+(673/24n^2)
= 1/12
I know this is wrong though...
I had a hard time decyphering what you typed. It's a bit difficult to oversee.
Try using LaTeX. (Click on the equations to see how it is used.)
It's much more neat too. :wink:
Anyway, you have:
[tex]\sum_{i=1}^{n}f(x_i)\Delta x[/tex]
[tex]f(x)=-\frac{x^2}{3}-7[/tex]
[tex]x_i=\frac{4i}{n}[/tex]
[tex]\Delta x=\frac{4}{n}[/tex]
So the sum is:
[tex]\sum_{i=1}^{n}\left(-\frac{16i^2}{3n^2}-7\right)\frac{4}{n}=-\frac{64}{3n^3}\sum_{i=1}^{n}i^2-\frac{28}{n}\sum_{i=1}^{n}1[/tex]
Here I've just split the sum into two in the last step. (I think you got this right).
Now for the first sum, use the identity:
[tex]\sum_{i=1}^{n}i^2=\frac{1}{6}n(n+1)(2n+1)[/tex]
So that:
[tex]-\frac{64}{3n^3}\sum_{i=1}^{n}i^2=-\frac{64}{3n^3}\frac{1}{6}n(n+1)(2n+1)=-\frac{64}{18n^2}(2n^2+3n+1)[/tex]
Then take the limit [itex]n\rightarrow \infty[/itex]
The first sum becomes [itex]-\frac{64}{9}[/itex]
The second sum is easy.
Simple integration of the first term gives:
[tex]\int_0^4\frac{-x^2}{3}dx = \frac{-x^3}{9}|^4_0=-\frac{64}{9}[/tex]
Which matches the sum. :smile:
PS: I`m glad we got the old smilies back, the new ones looked silly.
Edit: Corrected a silly mistake
Your calculus seems correct: you just need to work on your algebra skills. I think it would pay off for you to dig out your old texts and review.
The big thing you're missing here is the distributive law: (a + b) c = a c + b c, which holds for sums also [itex]c \sum (a + b) = c \sum a + c \sum b[/itex].
In particular:
When you factor something out of a sum, you have to factor it out of every term, not just one of them.
Conversely, when you expand, each term gets multiplied by the outside constant. Also, you can't just pull additive constants out of a sum. Remember that [itex]\sum (a + b) = \sum a + \sum b[/itex]
And don't forget that when you add fractions that you have to set up a common denominator before you can simply add the numerators. 1/2 + 3/5 is not 4/10... it's 5/10 + 6/10 = 11/10
Thanks guys I eventually figured out the rest of it!
I have another simple algebra problem (doing another problem like this now). How do I isolate the variable i here?:
lim n->infinity 5/n*sigma i = 1 to n of [(25-(5i/n)^2)^(1/2)]
Thanks.
You don't. :frown:
To do this limit, I think you either need to do some estimation (and prove that the error goes to zero as n goes to infinity), or find some other way to evaluate the integral.
Ah I noticed it finally. The area under that curve is a quarter circle with radius 5! Wow I'm so dumb sometimes. I got it now. Thanks. :)
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 16 ·
