| Thread Closed |
Capacitors and Power (two problems) |
Share Thread | Thread Tools |
| Jun29-10, 04:11 AM | #1 |
When a battery is attached to a capacitor, why do the two plates acquire charges of the same magnitude? Will this be true if the two conductors are different in size or shape? Explain. 2. Relevant equations Q=CV and C=epsilon x A/d 3. The attempt at a solution I wasn't sure if my answer was correct. I said, assuming the two plates are the same size and parallel, they will have the same capacitance, hence carry the same charge (from C=QV, where V is also the same for both plates). Also, the current flowing through the plates will be of equal, individual charges. As C=epsilon x A/d, this will not be true between conductors of different size and shape. This is because the capacitance will change, and they will be able to store different amounts of charges, hence may have different magnitudes. 1. The problem statement, all variables and given/known data When a lightbulb needs to be replaced, you have a choice between a 100-W bulb and a 75-W bulb. Which would draw more current? Which has the highest resistance? 2. Relevant equations V=IR, P=IV=I2R=V2/R 3. The attempt at a solution Wasn't very sure with this one. But, using the equations above, and assuming voltage is the same for both bulbs, the 100W bulb would draw more current, and since R=I/V, it would also have a larger resistance. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Jun29-10, 04:29 AM | #2 |
for question 1: You are talking about single capacitor in your problem. So there is only one capacitance not two in your circuit even though you change size/ shape of conductors.
The equation [tex] C=\frac{\epsilon A}{d} [/tex] holds for single capacitor. I don't know how you are considering it as two capacitors! Question 2: You are right in saying 100W bulb draws more current. But how you said that it has large resistance? It is contradicting because more resistance allows less current!!!! |
| Jun29-10, 04:34 AM | #3 |
woops.. Thanks! I started calling the two plates capacitors :| and for Question 2, I just rearranged the equation in my head wrong (thought R=I/V instead of R=V/I)
| Jun29-10, 04:37 AM | #4 |
For your first problem, you assume that both plates of the capacitor are initially uncharged. You will also assume that each terminal of the battery has zero initial charge. Using conservation of charge show that the charge on the plates of the capacitor are equal and opposite.
| Jun29-10, 04:38 AM | #5 |
Okay, thanks!
| Thread Closed |
| Tags |
| bulb, capacitor, current, power, resistance |
| Thread Tools | |
Similar Threads for: Capacitors and Power (two problems)
| many problems regarding power etc | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Improving power factor using capacitors (what capacitance?) | Introductory Physics Homework | 0 | ||
| Possible power related problems. | Computers | 9 | ||
| problems on capacitors | Introductory Physics Homework | 3 | ||
